Like Tree2Likes
Old 12-01-2003, 10:28 AM   #2851
Registered User
Calvin Ng's Avatar
Send a message via ICQ to Calvin Ng
Are the speedmind battery straps any good??
velcro
Calvin Ng is offline   Reply With Quote
Old 12-01-2003, 10:37 AM   #2852
Send a message via ICQ to Cobra81li200
Default Re: Caster
Originally posted by FTD RACING
Can someone please tell me if you can buy different caster blocks for a 414MII? If you can what are the part codes? If you canít do you alter it by adding spacers under the hinge pin mounts?
There were the original TA04 / TRF 414 ones, that were 8į I think, but I'm pretty sure they're discontinued, so yes we do like you said.
Cobra81li200 is offline   Reply With Quote
Old 12-01-2003, 11:03 AM   #2853
The Part number for the 04 castor blocks is 50870 and they are 8 degree's. They are still available.
JC
tiggersz is offline   Reply With Quote
Old 12-01-2003, 11:47 AM   #2854
talking of trimming the arms...
i seen some TRF drivers totally cut out the inside of there arms front ad rear, all of it just leaveing the 2 outer things...
what does this achive? lighter weight? more grip? i have no idea
cobra... upload the pics matey
Evo_Uk is offline   Reply With Quote
Old 12-01-2003, 11:57 AM   #2855
I can't they're property of the website... I can post their URL anyway.
taken from www.overrc.com
Thay said it provides more traction. My point is why then not use the standard plastic arms ?
Old 12-01-2003, 12:23 PM   #2856
Here is another pic of the mods to the arm. This is mainly when you run a very high roll center to clear the diff outdrives.
http://www.tamiya.com/japan/products/49175trf414m/setting_seat/6_22honguu.htm
JC
Old 12-01-2003, 12:29 PM   #2857
Yeah it's just what Surikarn did on his car when he won his title...
Old 12-01-2003, 12:30 PM   #2858
It is also to remove unsprung weight. This helps the tire make more traction because there is less mass to accellerate/decellerate from the wheel suspension assembly. Making the tire cna suspension follow/conform to the road better.
The practical side of this is it is of little benefit it does help some but you can only do it with the hard carbon arms as the plastic arms flex too much when the mat'l is removed.
UF1 Seattle - SPEEDWERKES - VBC Racing - Team ORCA
Difuser is offline   Reply With Quote
Old 12-01-2003, 12:36 PM   #2859
I meant, why remove material on the arms, if you want them to flex more then you can use the plastic arms.
The weight saved is ridiculous and they're not totally unsprung parts.
Old 12-01-2003, 06:22 PM   #2860
Registered User
Calvin Ng's Avatar
its probably cause the plastic ones are not as strong as these ones. but they still want less weight so they cut it
Old 12-03-2003, 06:37 AM   #2861
Registered User
Calvin Ng's Avatar
can someone dig out there wcr kit and tell me what the part number is for the center one-way and direct pulley
i herd that the wcr is diffrent from the 414MII and create more acceleration
Old 12-03-2003, 03:25 PM   #2862
Trader Rating: 23 (100%+)
on the wcr kit, it's listed as TA04 aluminium center one way pulley #53489
and TA04 aluminium center pulley # 53474
hope this helps!
poop is offline   Reply With Quote
Old 12-03-2003, 03:26 PM   #2863
Registered User
Calvin Ng's Avatar
ahhh ok
can someone confirm this will increase acceleration?
Old 12-03-2003, 03:32 PM   #2864
Default battery strap?
was wondering how you all secure your saddle packs to the chassis? anyone come up with a totally innovative way apart from velcro straps/battery tape?
thanks in advance!
Old 12-03-2003, 05:10 PM   #2865
I use the schumacher battery holders and they just work great.
414x x414x R/C Items: Wanted to Buy 3 06-30-2010 11:17 AM
looking for a tamiya 414x subaru73 R/C Items: Wanted to Buy 0 06-07-2006 08:50 PM
Tamiya 414x meche R/C Items: For Sale/Trade 2 09-12-2004 06:25 PM
Tamiya 414X icon R/C Items: Wanted to Buy 6 10-02-2002 07:58 PM
Looking for a 414x,414m,or TB Evo grinch77 R/C Items: Wanted to Buy 0 07-24-2002 05:22 PM
