Old 11-09-2003, 03:49 PM   #2746
Registered User
Calvin Ng's Avatar
Send a message via ICQ to Calvin Ng
dont worry
when you get your 414mII right your gonna be whipping those ta-02's
its just fatter teeth on the gear
so even if rocks get stuck it wont damage it as much
but the 414 has some problems with 48 pitch.... you'll have to ask around. some kinda fitting problem of some sort
Calvin Ng is offline   Reply With Quote
Old 11-09-2003, 05:34 PM   #2747
TRF-Powered's Avatar
I'm using 48 pitch spur by RW racing with no fitting problem. just remember when you switch to 48 pitch spur, you need to use a 48 pitch PINION gear also.
poop, Your driveway is wayyy dirtier and rockier than any outdoor track, for the reason that when a race is held, most likely that the race crew will prep the track by using leaf blower to clean out the small rocks.
TRF-Powered is offline   Reply With Quote
Old 11-10-2003, 12:04 AM   #2748
what do you guys do to stop 26mm wheels from rubbing.
Tamiya
Much More Racing
LRP electronic
Futaba
Speedtechrc
trf racer is offline   Reply With Quote
Old 11-10-2003, 05:51 AM   #2749
Trader Rating: 23 (100%+)
trf-powered:
so does a 48 pitch spur and pinion cure the problem of stuck stones?
thanks!
poop is offline   Reply With Quote
Old 11-10-2003, 05:58 AM   #2750
centax error!'s Avatar
add a shim/spacer between the wheel hex and the rim, tamiya sell those as options
centax error! is offline   Reply With Quote
Old 11-10-2003, 06:19 AM   #2751
Default 48 pitch
TRF-Powered:
Regarding 48 pitch spur/pinion, what combo do you have that works in the 414? I have tried KM 72, 75, 78 spur with 25 -30 pinions but I couldn't get them to mesh. If you can provide the spur size or teeth count that will be great. I am aiming for a final drive ratio of 7.0 - 7.3 range. I run a Novak Super Stock. Currently I am using the stock 120 with 34 pinion.
Pyramid:
Thanks for the tip on shimming the steeering rack. I put a 0.3 shim and it stops the up/down movement.
Supra66 is offline   Reply With Quote
Old 11-10-2003, 07:02 AM   #2752
lol.
ive used two 1mm shims and its still not enough.
ps your avatar is turning me on.
its very sexy.
Tamiya
Much More Racing
LRP electronic
Futaba
Speedtechrc
Old 11-10-2003, 08:01 AM   #2753
lol.
its very sexy.
yeah, add another 1 mm shim... wont work? you need to get the tamiya part # trf 415
everyone is saying the same thing on my avatar does she look asian to you ? a guy from the other thread said she looks western
CE!
Old 11-10-2003, 10:30 AM   #2754
Registered User
Calvin Ng's Avatar
lol she looks more azn then me! (i am chinese)
ha ha...
thats for adding shims to the car. i was trying to figure out hte exact same thing. sounds simple. im using like 29-30 mm in the rear and 28mm in the front so may have some problems
Old 11-10-2003, 10:33 AM   #2755
Registered User
Calvin Ng's Avatar
oh yeah by teh way peter solberg RULES!!!!
won the wrc drivers championship!!!
YAY favorite driver ever
for lancers i only like evo6's and lower... my favorite is the tommi makkinen edition
i hope subaru makes a PETER SOLBERG EDITION STI
because they did for richard burn... but only released in europe i beleive
Old 11-10-2003, 11:28 AM   #2756
Subaru made a Richard Burns edition subaru bit it was based on a STI 6 shape subaru not a STI7 like he won in. This was because he left Subaru at the end of his winning year and cost Subaru a lot of money in legal fees . The RB5 as it was so called was a celibration of his xth win in a subaru i think but it was not as fast as a P1 or a 22b i dont believe. Rick
Rick Draper is offline   Reply With Quote
Old 11-10-2003, 11:59 AM   #2757
NightKidZ's Avatar
Send a message via ICQ to NightKidZ
No offence, but Peter Steven's aero tweaks or not....
the JDM only STi202 would have beaten the P1.....
(ok ok, the JDMs fail Euro spec emissions :P)
22B........
The most extreme factory rex yet
Virtual clone to the Impreza WRC in the looks department.....
EXCEPT in a very small detail
(The 22B has smaller bonnet vents than the WRC car)
Now.. if only you guys over in Europe heard of a little Japanese tuning firm called Jun and their lemon yellow GDB.... kekekekekekek
Cheers
NightKidZ is offline   Reply With Quote
Old 11-10-2003, 12:30 PM   #2758
JDM? What is one of those? I was only compairing the RB5 to the P1 and the P1 is a better car. Rick
Old 11-10-2003, 06:59 PM   #2759
NightKidZ's Avatar
Hi Rick,
JDM = Japan Domestic Model
http://www.subaru-sti.co.jp/s202/index.html
The WRX STi S202 is a limited edition that comes factory tuned with 320 bhp, it was only availiable in Japan.
Cheers
Old 11-11-2003, 02:04 AM   #2760
Default Re: 48 pitch
Originally posted by Supra66
TRF-Powered:
Pyramid:
I'm currently using 92 Tspur with.... I think 30T pinion, which give me about 6.5... and i'm running a Team Orion Stock. I think with 92T spur you can go down as low as 26T pinion with no meshing problems. I'm not too sure. I also have a 89T spur which is giving me problem when I try to gear it with a 27T pinion. It simply won't touch. YOu just gotta try it out.
414x x414x R/C Items: Wanted to Buy 3 06-30-2010 11:17 AM
looking for a tamiya 414x subaru73 R/C Items: Wanted to Buy 0 06-07-2006 08:50 PM
Tamiya 414x meche R/C Items: For Sale/Trade 2 09-12-2004 06:25 PM
Tamiya 414X icon R/C Items: Wanted to Buy 6 10-02-2002 07:58 PM
Looking for a 414x,414m,or TB Evo grinch77 R/C Items: Wanted to Buy 0 07-24-2002 05:22 PM
