Old 10-27-2003, 09:00 PM   #2506
Registered User
Calvin Ng's Avatar
Send a message via ICQ to Calvin Ng
do you have to use the upper belt tensioner
do you use the lower chassis belt tensioner???
thanx for the help
Calvin Ng is offline   Reply With Quote
Old 10-28-2003, 01:38 AM   #2507
Send a message via ICQ to Cobra81li200
Yup, use the lower one, at least it prevents the belt from touching the battery.
For the upper one, I don't use it (as I don't have the brearings for it) and I don't have any problems.
Cobra81li200 is offline   Reply With Quote
Old 10-28-2003, 02:41 AM   #2508
FUK_WRX's Avatar
Send a message via ICQ to FUK_WRX Send a message via AIM to FUK_WRX Send a message via MSN to FUK_WRX Send a message via Yahoo to FUK_WRX
Default Manufacturing Question
Hey guys my friend and i are planning to manufacture some products for the 414M series, were trying to keep this superb baby alive. The only question is what requirements do we need to do this ?? Like license etc.. We got the connections and the tools
Hope can get all your support. The 414 is already a TB EVO killer i know we can stretch its potential even more.
FUK_WRX is offline   Reply With Quote
Old 10-28-2003, 07:14 AM   #2509
Trader Rating: 62 (100%+)
Default ATTN: FUK_WRX
414 guys, i apologize in advance for this offtopic reply
hi there FUK_WRX got your message in the other thread. our moderator was kind enough to text me about your post. thanks for sending the receiver
you have PM
marvi is offline   Reply With Quote
Old 10-28-2003, 08:18 AM   #2510
Where can you buy a chassis like the one above for 6x1 packs? I hate using saddle packs.
timc is offline   Reply With Quote
Old 10-28-2003, 03:11 PM   #2511
Registered User
Suradaj's Avatar
When you are running mod, putting the tensioner on the bottom does not work that well. When you rev up the motor the belt running on the lower side gets tight and lifts up a bit. Causing the belt to run mostly above the bearing. By putting the tensioner on the top, you can push the belt down and keeps it tighter.
Suradaj is offline   Reply With Quote
Old 10-28-2003, 03:35 PM   #2512
Registered User
Suradaj's Avatar
This is my 414M. I put a fan on the rear bulk head. Who knows if it helps any. I am going to put a motor heat sink on the motor and let the fan blow onto that.
Old 10-28-2003, 03:36 PM   #2513
Registered User
Suradaj's Avatar
Here is the pic of the fan. It a 5V fan so it pushes a lot of air.
Old 10-28-2003, 03:37 PM   #2514
TRF-Powered's Avatar
The world champ-style sway bar upfront of yours. did you polish the blue blocks to silver? or did it come like that? if it came like that, what's the item number?
TRF-Powered is offline   Reply With Quote
Old 10-28-2003, 03:39 PM   #2515
Registered User
Suradaj's Avatar
TRF...those are just the servo mounts. I just drilled and taped them.
Old 10-28-2003, 03:42 PM   #2516
Registered User
Suradaj's Avatar
TRF...here is a closer pic. Sorry it didn't come out that well.
Old 10-28-2003, 03:53 PM   #2517
ah ic... Thanks...
I know that the world-champ style sway bar for the TA04 comes with SSG carbon piece and silver support blocks. i dunno if it fits the 414M chassis though.....
I have a bone-stock silver M.... I have been thinking to hoping it up... but can't find all silver parts for it....
Old 10-28-2003, 04:02 PM   #2518
Registered User
Suradaj's Avatar
TRF...the surport blocks will work but the SSG carbon piece is wider then the one for the 414M.
I noticed in the picture that is has blue blocks? Must not come in the kit then.
Old 10-28-2003, 04:09 PM   #2519
the one comes with TA04TRF has blue blocks... but if you buy it seperately... it comes with silver...
Old 10-28-2003, 04:14 PM   #2520
Registered User
Calvin Ng's Avatar
sweeet
keep the 414 alive!!!
you took the 5v fan thing from me. i was going to do the exact same thing
i herd that using a fan is better then using a heatsink. putting a heat sink on it and blowing at it is woarse then blowing on the motor itself
is there a reason why i shouldnt be blowing a fan at my brushless??
414x x414x R/C Items: Wanted to Buy 3 06-30-2010 11:17 AM
looking for a tamiya 414x subaru73 R/C Items: Wanted to Buy 0 06-07-2006 08:50 PM
Tamiya 414x meche R/C Items: For Sale/Trade 2 09-12-2004 06:25 PM
Tamiya 414X icon R/C Items: Wanted to Buy 6 10-02-2002 07:58 PM
Looking for a 414x,414m,or TB Evo grinch77 R/C Items: Wanted to Buy 0 07-24-2002 05:22 PM
