Old 10-15-2003, 03:27 PM   #2386
Registered User
Calvin Ng's Avatar
Send a message via ICQ to Calvin Ng
no way
the guy from tamiya the designed it went to hpi... thats why they made a evo 3 to replace it
dont matter ta-04 parts work on it anyways
Calvin Ng is offline   Reply With Quote
Old 10-15-2003, 03:29 PM   #2387
yeah I guess so, its a big shame really.
g4t2 is offline   Reply With Quote
Old 10-15-2003, 03:31 PM   #2388
Registered User
Calvin Ng's Avatar
i totally agree
just wondering but
what are companies that make parts for 414mII besides tamiya??
i know square, kai and racy
anymore?
Old 10-15-2003, 03:31 PM   #2389
fowlerJr68's Avatar
Any of you guys want 2 buy a green 414M2 wit ssg chassis?
Steve
fowlerJr68 is offline   Reply With Quote
Old 10-15-2003, 03:34 PM   #2390
Erm theres a company called Mirage, but its for ta04. Squat make vibration control bearings. thats all i can think of. what spec is your 414 calvin?
Old 10-15-2003, 05:37 PM   #2391
Registered User
Calvin Ng's Avatar
Steve
intrested in trading????
tc3 with some spares
Old 10-15-2003, 08:34 PM   #2392
fowlerJr68's Avatar
No thanx..i'm trying to get rid of my TC3...i would only trade for a Cuda...
thanx
STeve
Old 10-16-2003, 09:37 PM   #2393
weissjim's Avatar
R/C Tech Charter Subscriber
How many green 414's are there, this is like the third one this month?!? Was green an optional color?
weissjim is offline   Reply With Quote
Old 10-17-2003, 04:34 AM   #2394
fowlerJr68's Avatar
No, it's not an option..you have to get it anodized..
Steve
Old 10-17-2003, 08:56 AM   #2395
Send a message via ICQ to Cobra81li200
Evaa
Try one after the other (not all on the same run) the following :
- Higher rear anti roll bar (I'd go for the blue or the world one),
- adding spacers under the rear turnbuckle on the bulkhead side,
- adding anti dive by adding a spacer (0.7 mm for example) under the rear front suspension mount (so you'd get 1,4 mm under it, also recommended if track is bumpy),
- adding rear toe-in (you did not say how much you have, I guess 2 overall, beware of overheating your tires, ie : if they scream they're too hot, then lower the rear toe in),
- stiffer rear springs (go for the yellow),
- shock location inner on the shock mount,
- less toe in / more toe out (depends on what you have) on front.
As you can see, there are lot of ways to give more traction to the rear, and I did not listed all of them.
I must add, be careful about tweaking on this chassis, as it is very stiff, if tweaked it will have strange reactions. The same occurs when the left/right rebound is not the same.
Anyway, I love that car, gonna get it back to race right now, as my SD is waiting for spares to get back onto racing...
Cobra81li200 is offline   Reply With Quote
Old 10-17-2003, 01:13 PM   #2396
Default 48pitch Spur and Pinion
Does anyone run 48 pitch Spur/Pinion combo? I am having a hard time finding the right size combo to get a 7.5 ratio. So far I have got Kimbrough 48P 72, 75, 81 & 84 spurs and 48P 25T thru 30T pinions and none of the combo works.
Before I go out and buy more spurs, I would like to get some advice as to what size will fit in the 414 to yeild a 7.5 ratio. I run on unprepared surface so the stock spur and pinion got chew up pretty badly.
Supra66 is offline   Reply With Quote
Old 10-17-2003, 03:20 PM   #2397
Registered User
Calvin Ng's Avatar
yeah 48 pitch is a problem
i tried it tooo......
you have to use like 100 teeth spurs to fit it....
the only reason i used 48 pitch is 64 pitch spurs brake so easily..
i prefer 64 pitch but i wanna find some kind of protection for the spur/pinion gears
Old 10-17-2003, 05:33 PM   #2398
Hi wondering if any of you guys had any pics of the TRF 404X? If so, please post them. thanks
Old 10-18-2003, 11:07 AM   #2399
Topforce's Avatar
Default Re: 48pitch Spur and Pinion
You need a 92 spurgear with a 26 pinion which will give you 7.54. And i think it will fit on the car. RW has an 92 48dp spurgear, so check at your lhs if they have them in stock or maybe they can order them. I thought RW is distributed by schumacher USA.
Correct me if I am wrong.
Arjan
Topforce is offline   Reply With Quote
Old 10-18-2003, 11:13 AM   #2400
Registered User
Calvin Ng's Avatar
nm sorries
thought you got the final wrong
414x x414x R/C Items: Wanted to Buy 3 06-30-2010 11:17 AM
looking for a tamiya 414x subaru73 R/C Items: Wanted to Buy 0 06-07-2006 08:50 PM
Tamiya 414x meche R/C Items: For Sale/Trade 2 09-12-2004 06:25 PM
Tamiya 414X icon R/C Items: Wanted to Buy 6 10-02-2002 07:58 PM
Looking for a 414x,414m,or TB Evo grinch77 R/C Items: Wanted to Buy 0 07-24-2002 05:22 PM
