Old 01-14-2002, 07:39 PM   #226
Joehwee's Avatar
Alex: My car weight 1450g with the followings equipment onboard:
- M'tronik Prodigi Max 2000 ESC
- Sanwa 2 channel Receiver
- KO 2123 Servo
- Sanyo RC3000 fasten with Glass tape
- D4 11x3 Motor
- Front diff with light weight outdrive
- Light weight at rear diff
- Alumnium center direct drive pulley
- F&R Roll Bar
- Cross Alumnium Steering Kunckle
- Original Dish Rim, Sorex tyres and inserts
- Protoform Dodge Stratus bodyshell
I have added 55g of lead weight under the steering rack to get the car to be at the legal weight.
Joehwee is offline   Reply With Quote
Old 01-15-2002, 05:41 PM   #227
badboy's Avatar
Trader Rating: 14 (100%+)
FRONT ONEWAY UNIT AND CENTER LAY SHAFT ONEWAY
GUYS,
If i'll install a front oneway unit of my TA04 do i still need to install another oneway for the center lay shaft? can you give me the pros and cons of adding a oneway. do i need to install both or if i install the front oneway there is no use for the center oneway anymore?
thanks!!!
slow is fast . . .
badboy is offline   Reply With Quote
Old 01-16-2002, 10:31 AM   #228
sonneteer's Avatar
Is it a dual one way you are talking about? I got the dual type therefore it is virtually drag-free!
The front one way will make your car turn in faster and having more steering. You wone scrub off much speed like 4WD would.
The neg side is you only get rear wheel braking... and if you back off throttle too quickly it can unsettle you car into a spin... without even touching the brakes!!! especially on slippery surface... ( that is why I got full time 4WD now as the weather is no good over here! and I am not that good yet....)
There is not much point having the front OW and the OW lay shaft together.... if you got he one way lay shaft it pretty does the same job but you get more drag due to the belts and the front diff etc....
2 pennies worth....
sonneteer is offline   Reply With Quote
Old 01-17-2002, 08:28 PM   #229
Send a message via ICQ to hattchris
I don't know if you guys have tried this before but to get moe control over the car on high traction carpet take the stock TA04 C hubs and cut off the ear where you usally connect the the upper link. then take the Ball / king pin from the 414 chubs and put that and use it like you would usally
the 7 degree hubs seam to give a little better handing
Just thought iwould tell people
it is a way alot of the fast guys around here run them
hattchris is offline   Reply With Quote
Old 01-17-2002, 08:59 PM   #230
Aurra Sing's Avatar
I just wanted to inform everyone that my TRF414M will be picked up tomorrow (Friday) morning. Hehe!
Aurra Sing is offline   Reply With Quote
Old 01-19-2002, 10:24 AM   #231
Aurra Sing's Avatar
Here are some pics of my brand new Tamiya TRF414M. I got it yesterday afternoon, finished last night.
Question: What is the purpose of the dual-collars? What does the 2nd collar do?
Question: I have 4 spare suspension shafts, are they part of the spare parts Tamiya gives you?
Later, I'll post scans of the front sway bar setup the guys in Japan are doing.
Old 01-19-2002, 10:37 AM   #232
TRF-Powered's Avatar
Aurra Sing,
Where did you get your TRF 414M??? didnt tamiya usa run out of it long time ago?
The dual collar on the damper, the second one supposly secure the first one so during excessive damping the collar doesn't unintenally unscrew itself.
TRF-Powered is offline   Reply With Quote
Old 01-19-2002, 10:54 AM   #233
Aurra Sing's Avatar
Got it on eBay! Probably the only place you can get them now.
Old 01-19-2002, 10:55 AM   #234
how much did you pay for it?
Old 01-19-2002, 11:56 AM   #235
Aurra Sing's Avatar
I keep that confidential.
Old 01-19-2002, 11:10 PM   #236
Aurra Sing's Avatar
Here's that front stabilizer setup I was talking about.
This is a prototype (?) arm. Notice the ball end for the stabilizer mount.
Old 01-19-2002, 11:11 PM   #237
Aurra Sing's Avatar
different pic
Old 01-19-2002, 11:11 PM   #238
Aurra Sing's Avatar
another pic
Old 01-20-2002, 03:46 AM   #239
rccarracer's Avatar
Aurra nice car!! Will you convert it for saddle packs?
Anyway one thing I feel I should pass on as one 414M owner to another is to remove two of the four rear spacers for the upper shock mounts. This is so the shocks are straight up and down, and no tilted out like they are at the moment. It reduces some of the stress on the shocks.
With those pics you attached, have you been able to do a translation of the text?I'd like to know the reason for the change.
Again nice car!!
rccarracer is offline   Reply With Quote
Old 01-20-2002, 03:52 AM   #240
rccarracer's Avatar
It looks as if they are trying to replicate the front stabilizer from the Yokomo Special!!
That the stabilizer goes over the whole setup and comes from the centre of the chassis out and not from the front of the chassis to the centre, if you know what I mean.
414x x414x R/C Items: Wanted to Buy 3 06-30-2010 12:17 PM
looking for a tamiya 414x subaru73 R/C Items: Wanted to Buy 0 06-07-2006 09:50 PM
Tamiya 414x meche R/C Items: For Sale/Trade 2 09-12-2004 07:25 PM
Tamiya 414X icon R/C Items: Wanted to Buy 6 10-02-2002 08:58 PM
Looking for a 414x,414m,or TB Evo grinch77 R/C Items: Wanted to Buy 0 07-24-2002 06:22 PM
