Like Tree2Likes
Old 10-02-2003, 08:24 PM   #2341
weissjim's Avatar
R/C Tech Charter Subscriber
Calvin
I think Tamiya makes the 500w oil and I believe its close to 50w. Of course every manufacturer has a slightly different spin on weight, so your results may vary.
I'm sort of confused on the ackerman post, I thought I read elsewhere on this thread that I wanted the "inner" holes if I wanted more ackerman?!? Do you know how the geometry works to figure this out?
To the thread...
Here's a little nugget I found. The suspension balls p/n 9805739 (MP1) is now p/n 50994. They work on the EVO III and TRF414M2. These are the balls that fit on the hinge pins that go bouncing across the floor when you change the anti-dive/anti-squat spacers.
weissjim is offline   Reply With Quote
Old 10-02-2003, 08:39 PM   #2342
Registered User
Calvin Ng's Avatar
Send a message via ICQ to Calvin Ng
can you explain what ackerman is to me
i've been trying to figure it out. i read magz and stuff but they tell you what it does and stuff but doesnt tell how to adjust it
Calvin Ng is offline   Reply With Quote
Old 10-02-2003, 09:58 PM   #2343
NightKidZ's Avatar
Send a message via ICQ to NightKidZ
Ackerman refers to the difference in the amount turned by the inside and outside front wheel when the car is steered to one side. Usually the Ackerman angle is set such that the inside wheel turns less than the outside wheel.
To adjust the amount of Ackerman your car has, adjust the length of the turnbuckle between the two steering bell cranks. If I am not mistaken, the longer that link is, the more Ackerman effect you will have.
Cheers
NightKidZ is offline   Reply With Quote
Old 10-03-2003, 06:31 AM   #2344
Registered User
Calvin Ng's Avatar
what the heck are the balls then?
Old 10-03-2003, 07:51 AM   #2345
Registered User
Suradaj's Avatar
What holes are good to start with on the shock towers of the 414M? For the camber links.
Suradaj is offline   Reply With Quote
Old 10-03-2003, 03:09 PM   #2346
Registered User
Calvin Ng's Avatar
middle ones
what kinda track you running on?
Old 10-04-2003, 09:23 AM   #2347
weissjim's Avatar
Night Kidz
Thanx, that explains it and it fits Calvins description of the adjustment. I looked at the car last night and moving the tie rods to the "outer" hole will require a longer tie rod, which by the definition you gave should increase ackerman.
Calvin
Sorry for the confusion, the suspension balls are unrelated to ackerman. They are just replacement parts that I happened to find. The original part number (9805739) is listed as out of stock on Speedtech, but you can get the 50994 from almost anyone. The part is the little 5mm balls with the 3mm hole through them that fit on the hinge pins and ride in the suspension blocks.
Old 10-04-2003, 09:35 AM   #2348
Registered User
Calvin Ng's Avatar
lol i still dont know what your talking about...
i dont know my terms for r/c
oh nm i found out. it is the part that attaches to the shaft that holds the arm ok cool.
Old 10-04-2003, 09:38 AM   #2349
Registered User
Calvin Ng's Avatar
another thing im trying to find out is how do you adjust your front upright to C1 or C2??????
i asked some people and i kinda knew what they were talking about but not really pics would help
and whats the diffrence between the flourine coated shocks and the normal blue ones that come with the 414mII
Old 10-04-2003, 10:19 AM   #2350
Aurra Sing's Avatar
Joey - I tried the Inner/Middle hole in front, and Inner/Lower hole in rear when I ran them on the shock tower. I think it most replicates the Evo3 upper links as much as possible.
Aurra Sing is offline   Reply With Quote
Old 10-04-2003, 10:23 AM   #2351
Aurra Sing's Avatar
To change the uprights, just switch them with each other. The kit setup is left: C1, right: C2. So to switch it, you would make it left: C2, right, C1. Don't forget to reset your droop since it will also affect the droop setting.
Flourine shocks have a special coating and are somewhat smoother than the standard blue TRF shocks.
Old 10-04-2003, 11:17 AM   #2352
Registered User
Calvin Ng's Avatar
whast the diffrence between those two?
Old 10-04-2003, 07:43 PM   #2353
Regional Moderator
hey guys i have this for sale or trade?
Ko Racer is offline   Reply With Quote
Old 10-04-2003, 08:17 PM   #2354
weissjim's Avatar
Sweet -
Is this the "money green" 414 that was listed awhile back? What are you asking?
Old 10-04-2003, 08:23 PM   #2355
Regional Moderator
Originally posted by weissjim
Sweet -
its close this has all the SSG goodies on it its in the sale part of the forum check it out
414x x414x R/C Items: Wanted to Buy 3 06-30-2010 11:17 AM
looking for a tamiya 414x subaru73 R/C Items: Wanted to Buy 0 06-07-2006 08:50 PM
Tamiya 414x meche R/C Items: For Sale/Trade 2 09-12-2004 06:25 PM
Tamiya 414X icon R/C Items: Wanted to Buy 6 10-02-2002 07:58 PM
Looking for a 414x,414m,or TB Evo grinch77 R/C Items: Wanted to Buy 0 07-24-2002 05:22 PM
