Old 08-07-2003, 08:57 PM   #2311
rcspeedo's Avatar
With the blue blocks, you can raise it higer than the silver blocks by shimming without hitting the belt, thus changing the roll center of the car and will also affect caster.
rcspeedo is offline   Reply With Quote
Old 08-07-2003, 11:22 PM   #2312
Registered User
Calvin Ng's Avatar
Send a message via ICQ to Calvin Ng
sorry
just answered it myself
no need for a post
Calvin Ng is offline   Reply With Quote
Old 08-12-2003, 01:31 AM   #2313
Vic
Vic's Avatar
Hi,
Did you Guys ever experienced this:I am using front and rear diffs in my car and sometimes during a run either the front or the rear diff tightens itself obviously the car gets undriveable.
I need to losen it afterwards, is there a way not to get into this problem it is quite annoying especially during a race.
Should I be cleaning the diffs more often or what to do not to get into this ever again?
Thanx in advance!!!
Vic is offline   Reply With Quote
Old 08-12-2003, 01:49 AM   #2314
FUK_WRX's Avatar
Send a message via ICQ to FUK_WRX Send a message via AIM to FUK_WRX Send a message via MSN to FUK_WRX Send a message via Yahoo to FUK_WRX
Originally posted by Vic
Hi,
Thanx in advance!!!
Seems like you dont have any lubrication in the diffs you better start rebuilding them, make sure you use the tamiya ball diff grease, not just ordinary grease build it as is in the intrusctions
Hope this helps.
FUK_WRX is offline   Reply With Quote
Old 08-12-2003, 02:02 AM   #2315
Vic
Vic's Avatar
Thanx for your help!
Should I be putting a lot in the inside and clean it off after it is put together?
Old 08-12-2003, 02:06 AM   #2316
Vic
Vic's Avatar
Another question:How often should I clean and rebuild my diffs?
Old 08-12-2003, 02:18 AM   #2317
FUK_WRX's Avatar
dismantle the diffand clean it out individually with motor spray or metholated spirits, make sure there no grit, dust etc..
plance a considarable amount of ball diff grease in each ball, then smir off a little grease in the rings also, it would be an ideal to turn the rings around the opposite way incase there is any wear on them.
Make sure also to grease the thrust ball, then simply just build it up tighten the diff screw until you cannot feel any slip when you turn the diff pulley.
Old 08-12-2003, 02:25 AM   #2318
Vic
Vic's Avatar
Thanx for your help!I will give it a try!
Old 08-12-2003, 12:31 PM   #2319
Aurra Sing's Avatar
It could also be the M2 nut. Replace it if it is worn.
Aurra Sing is offline   Reply With Quote
Old 08-12-2003, 08:22 PM   #2320
WC
WC's Avatar
Trader Rating: 28 (100%+)
Degrease the screw & nyloc nut; when reassembling put a little
Tamiya Threadlock on the nut. (Use the blue Tamiya stuff, as this
does not dry totally hard and remains tacky afterwards).
You might also want to check your Thrust Bearing.
If this has jammed, it will unthread your diff screw.
Clean it out and stuff it with diff grease.
As for amt of grease... "less is more".
I stick with the Tamiya Ball Diff Grease, no reasons to change.
I'm of the "put the grease & balls into a little baggy & squish"
school. Take the balls out & install, the grease smeared on them
is enough for the whole diff. The rings don't need greasing.
Rebuild your diff when it feels gritty.
WC is offline   Reply With Quote
Old 08-13-2003, 02:15 AM   #2321
Vic
Vic's Avatar
Thanks a lot to everyone it has been very usefull!
Old 09-08-2003, 10:37 PM   #2322
TK
TTT
TK is offline   Reply With Quote
Old 09-11-2003, 08:23 AM   #2323
Hi,
I am looking for lightweight bulkhead and lightweight aluminum motor mount,
Do you know who still carry these parts ?
Thx
Ralf is offline   Reply With Quote
Old 09-11-2003, 09:31 AM   #2324
cHckbOY5's Avatar
Send a message via AIM to cHckbOY5
ebay
cHckbOY5 is offline   Reply With Quote
Old 09-14-2003, 06:37 PM   #2325
Wilfred's Avatar
Like to know how light can you go with your 414m2? in grams pls. and with body and batts.
Wilfred is offline   Reply With Quote
414x x414x R/C Items: Wanted to Buy 3 06-30-2010 12:17 PM
looking for a tamiya 414x subaru73 R/C Items: Wanted to Buy 0 06-07-2006 09:50 PM
Tamiya 414x meche R/C Items: For Sale/Trade 2 09-12-2004 07:25 PM
Tamiya 414X icon R/C Items: Wanted to Buy 6 10-02-2002 08:58 PM
Looking for a 414x,414m,or TB Evo grinch77 R/C Items: Wanted to Buy 0 07-24-2002 06:22 PM
