Old 07-27-2003, 02:03 AM   #2296
TRF-Powered's Avatar
Does anyone know if Tamiya released a thinner suspension block for the front-rear spot? When i tried to raise the suspension block, I realized that the belt is rubbing against the front-rear suspension block. It's impossible to have the same set up as the world-champ withouth the belt rubbing againist the block since he raised the suspension block so high.
Or did you all just mount the suspension block upside-down?
TRF-Powered is offline   Reply With Quote
Old 07-27-2003, 09:44 AM   #2297
rtypec's Avatar
TRF: I took a dremel to a supsension block and created my own channel The idea is to remove the least amount of material while making sure that you have enough clearance for the belt. Yes it was time consumming, but hey you only need to do it once
Also, they did release a special block with the WCR kit. I tried to order it at one point, but never got it. There is a part number for it, but I don't know what it is anymore. Sorry.
rtypec is offline   Reply With Quote
Old 07-27-2003, 09:47 AM   #2298
Registered User
Calvin Ng's Avatar
Send a message via ICQ to Calvin Ng
where does the belt rub i dont know what you guyz are talking about
any pics?
Calvin Ng is offline   Reply With Quote
Old 07-28-2003, 12:42 AM   #2299
Pyramid's Avatar
any pics?
Click on my signature (Daltonshop) then enlarge/klik the second picture from the right. Blue susp is original from WCR kit.
Pyramid is offline   Reply With Quote
Old 07-28-2003, 12:50 AM   #2300
Pyramid's Avatar
I'm not sure if you all still using this car nor this matter already discuss, but if you need about 20% more of steering for your 414M (compared to original/manual setting), use this method;
Place the servo at its original place using the supplied (long) turnbuckle (not the other way around like the world champs)
Switch the position of front knucle C1/C2 from the manual so that if you were looking at the car from behind, C1/C2 words are upside down.
Use the outer hole of C1/C2 for steering turnbuckle, not the second hole like the manual suggest.
All of those mods is to adjust ackerman angle and you will feel it right away.
Hope it helps
Old 07-28-2003, 01:14 AM   #2301
Thanks for the advise! I will try to do that... but the thing is... is that mod make it illegal for TCS?
Old 07-28-2003, 01:25 AM   #2302
GTMilenko's Avatar
i don't really know what i'm talking about here, but wouldn't a sus block from the EVO III work?
GTMilenko is offline   Reply With Quote
Old 07-28-2003, 02:18 AM   #2303
I tried it with EvoII suspension block which are lower than the EvoIII block (EvoIII block has additional 2mm lift), and it didn't work. the belt is still rubbing against the suspension block.
Old 07-28-2003, 04:41 AM   #2304
The evo3 blocks gives you over 4mm clearance of the belt. I have them on my car and highly recommend them.
Mr_Orange is offline   Reply With Quote
Old 07-28-2003, 04:09 PM   #2305
Aurra Sing's Avatar
I'm selling my 414M: Used Tamiya TRF414M (silver) for sale
Yes, I want to get an Evo3.
Aurra Sing is offline   Reply With Quote
Old 08-06-2003, 05:54 PM   #2306
Registered User
Calvin Ng's Avatar
im looking for a setup for the 414mII
its for a low grip parkinglot kinda pavement
with a one-way (new blue one)
and the wcr conversion kit
with yokomo 138/139 tires (not sure if its the right info)
anyone?
Old 08-06-2003, 10:13 PM   #2307
Pyramid's Avatar
anyone?
Go with the worlds setup, it pretty much working on all surface or try to scroll a few months back within this threads
Old 08-07-2003, 11:57 AM   #2308
Registered User
Calvin Ng's Avatar
k i'll give it a shot
Old 08-07-2003, 04:38 PM   #2309
rcspeedo's Avatar
The blue suspension blocks that come with the 414MII WRC are weak ! . From what I can tell, this is because of the amount of material that has been shaved off from the original silver block.
The info for the block is :
3454156, TAMIYA, Suspension Arm Block B (414M Worlds Replica Chassis - Blue)
I ordered mine from rainbow ten. I'll probably order some more since I have no more spare.
rcspeedo is offline   Reply With Quote
Old 08-07-2003, 06:21 PM   #2310
Registered User
Calvin Ng's Avatar
what improvements will you see when you change it to the b ones/new ones?
414x x414x R/C Items: Wanted to Buy 3 06-30-2010 12:17 PM
looking for a tamiya 414x subaru73 R/C Items: Wanted to Buy 0 06-07-2006 09:50 PM
Tamiya 414x meche R/C Items: For Sale/Trade 2 09-12-2004 07:25 PM
Tamiya 414X icon R/C Items: Wanted to Buy 6 10-02-2002 08:58 PM
Looking for a 414x,414m,or TB Evo grinch77 R/C Items: Wanted to Buy 0 07-24-2002 06:22 PM
SEO by vBSEO 3.5.0
