Old 03-03-2003, 11:25 PM   #2116
peter_robinson's Avatar
Trader Rating: 21 (100%+)
the only way that those screws are coming out now are by way of dremel.
you are going to have to cut a slot in the head of the screw (yes to get a deep enough slot to do much good you are going to have to cut into the graphite too), and remove them with a blade screw driver.
but dont worry, i picked up satoshi's car at worlds and it had a few slots in the graphite too, so this even happens to the best of us
peter
For orders or inquiries, email sales@rc-trim.com. Follow RC-Trim on Twitter and Facebook
RC-Trim | Serpent USA | On-Point | Trinity | Revtech | ORCA | BSR | KO Propo | PT RC Racing Oil | WTRC | rcpitwhores.com
peter_robinson is offline   Reply With Quote
Old 03-04-2003, 08:56 AM   #2117
TRF-Powered's Avatar
I have a M2 that have the world sway bar in front. I got a question for those also have this set up.
I notice that the right wheel would touch the turnbuckle that the swar bar is fixed to when it's turned to the max. Did any of you have this problem? I tried to fix this by adding the wheel spacer in there and it does add a little space between the wheel and the turnbuckle. However, it still worries me that during a light bump the wheel will still hit the turnbuckle and slow down one wheel and cause a spin out.
Any ideas?
TRF-Powered is offline   Reply With Quote
Old 03-04-2003, 10:06 AM   #2118
imataquito's Avatar
Send a message via ICQ to imataquito Send a message via Yahoo to imataquito
no excess to dremel ...... and i dont know where to get one...
any online shops which sells one??
or .... where can i find them ??
thanks
imataquito is offline   Reply With Quote
Old 03-04-2003, 04:53 PM   #2119
Default Stripped hex heads
I've had good luck removing the screws using an 'easy out'. I'm not sure I've got the name right. It looks like a thread tap only the threads are reversed. It digs in when turned counter clockwise.
dalem is offline   Reply With Quote
Old 03-04-2003, 11:39 PM   #2120
imataquito's Avatar
.....? where can i find those.... ?
Old 03-05-2003, 01:19 PM   #2121
Auto part stores carry them. Just tell them you need to tool to remove a broken bolt. The set I have is called a 'screw extraction set'.
Old 03-05-2003, 07:17 PM   #2122
imataquito's Avatar
ok i will try .....
dang i guess my car will be out of action for some time ...
it is a common problem to get stripped heads (hex)
i know that if u use a wrong tool for it i will strip but i specially bought a proper tool for the screws...
is there any type of screws which does not strip ?
Old 03-07-2003, 04:41 PM   #2123
GTMilenko's Avatar
if you have a screw stuck you can just drill it out, use the same size drill bit as the screw, drill it out carfully, this will remove the head of the screw, then remove the thread left over with a pair of pliars, easy, i've done it. no damage to anything but the screw.
hope this helps
GTMilenko is offline   Reply With Quote
Old 03-07-2003, 06:27 PM   #2124
Default SSG parts?
So, what up with these new SSG parts.
Any difference to the `normal' CF parts?
What the heck does SSG stand for anyways?
Cheers
Andrew
awauckland is offline   Reply With Quote
Old 03-08-2003, 11:37 AM   #2125
weissjim's Avatar
R/C Tech Charter Subscriber
Default Spacer Question
Is there a Tamiya part number for the spacers you use to set the "anti-squat" on the 414? I know Kose makes them too, but I can't find a web site in English that I can buy them from
TIA
weissjim is offline   Reply With Quote
Old 03-08-2003, 02:10 PM   #2126
Jim
Ray has them in stock @ Burien have Kevin bring a set up for you to Rain City
UF1 Seattle - SPEEDWERKES - VBC Racing - Team ORCA
Difuser is offline   Reply With Quote
Old 03-10-2003, 08:54 PM   #2127
Trader Rating: 62 (100%+)
has anyone tried converting the front one-way into a spool? can you lock the one way bearings onto the outdrives? or is the ball diff the only one that can be converted into a spool? thanks for any info
marvi is offline   Reply With Quote
Old 03-16-2003, 06:40 PM   #2128
very quiet here
Old 03-16-2003, 06:49 PM   #2129
Pyramid's Avatar
Hi Marvi,
can you give me a quick explanation on advantages of using a spool in rear? many thanks
Weissjim,
Try Tobbe craft if you could not get the original blue anodize from tamiya. They makes them for 3mm screws.
Pyramid is offline   Reply With Quote
Old 03-18-2003, 09:23 PM   #2130
pyramid: sorry but i havent used a spool yet so i cant answer your question. i wanted to try using a front spool just to experiment if it will improve handling, but as of now, im still running front & rear diffs. i dont know what the effect would be if it will be used for the rear of the car. maybe using a spool in the rear would be useful for fast and flowing tracks - mainly because some 1/10 nitro cars that have front one-ways and locked rear diffs run on similar tracks.
414x x414x R/C Items: Wanted to Buy 3 06-30-2010 11:17 AM
looking for a tamiya 414x subaru73 R/C Items: Wanted to Buy 0 06-07-2006 08:50 PM
Tamiya 414x meche R/C Items: For Sale/Trade 2 09-12-2004 06:25 PM
Tamiya 414X icon R/C Items: Wanted to Buy 6 10-02-2002 07:58 PM
Looking for a 414x,414m,or TB Evo grinch77 R/C Items: Wanted to Buy 0 07-24-2002 05:22 PM
