Old 02-28-2003, 10:27 AM   #2101
Mike I did similar on my EVO
1. Use CA and place them back to back with smooth to the diff ring grit to the diff gear
6.Yes use the Losi pads they work fine and only 2-3 dollars I think. They come with at least 4 pads and maybe even 6-8 the pack I got had 8-9 of them.
Hope it helps
D
UF1 Seattle - SPEEDWERKES - VBC Racing - Team ORCA
Difuser is offline   Reply With Quote
Old 02-28-2003, 02:05 PM   #2102
Regional Moderator
Send a message via AIM to Mike F
Ah, so you glue them to the actual diff ring
Mike F is offline   Reply With Quote
Old 02-28-2003, 03:08 PM   #2103
Correct if you want to re-use the ring you could re-polish the rings to remove the CA. I would just purchase new ones
Old 02-28-2003, 03:36 PM   #2104
Regional Moderator
cool, thanks
Old 02-28-2003, 06:42 PM   #2105
littledog's Avatar
R/C Tech Charter Subscriber
Originally posted by Mike F
Check your Xray and see if it does it on that one as well. If it doesn't, what's different on that kit then the 414M2
I an't do that as my x-ray has pillow ball. lol
littledog is offline   Reply With Quote
Old 02-28-2003, 11:16 PM   #2106
weissjim's Avatar
hey difuser,
Just got in from Rain City with Kevin's former 414. Picked up a full second over my previous best lap and I'm nowhere near done dialing it in. The TRF414M2 is unbelievable.
Thanx for the heads up, I couldn't be happier with this car.
weissjim is offline   Reply With Quote
Old 03-01-2003, 01:05 AM   #2107
peter_robinson's Avatar
Trader Rating: 21 (100%+)
mike f
i did indeed use CA to glue the parts mentioned, and i uses CA for all steps where i mentioned "glue"...
the reason for doubling up the sand paper is to achieve the correct thickness so that you do not need to waste a set of diff rings (and the sand paper does not glue well to the steel diff ring anyway)
when you double them up, make sure things go in this order- rough side/smooth side, glue(CA), rough side/smooth side...
where the "rough side/smooth side" is one piece of sand paper.
then you can glue (CA) this double thick piece of sand paper to the black plastic ring holder that is part of the 414 diff out drive set. this allows you to change out the outdrive if they become worn or damaged, and just switch your spool pad over to the new outdrives (like i said, even better then losi's idea)
peter
For orders or inquiries, email sales@rc-trim.com. Follow RC-Trim on Twitter and Facebook
RC-Trim | Serpent USA | On-Point | Trinity | Revtech | ORCA | BSR | KO Propo | PT RC Racing Oil | WTRC | rcpitwhores.com
peter_robinson is offline   Reply With Quote
Old 03-01-2003, 01:08 AM   #2108
and sorry to all of those who manted pics of the spool assembly, i am still learning my camera
if you PM me with your email address, i will try to get them to you, though it may not be right away as i am trying to get packed to go to the carpet nats next weekend.
peter
Old 03-01-2003, 11:31 AM   #2109
Regional Moderator
OK peter. Thanks.
So your not using the diff rings but making replacements with sand paper then gluing them on the black plastic rings, correct
Old 03-02-2003, 01:03 PM   #2110
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
i had a question... somewhere, i have seen a pic of a 414 with X-ray battery mounts, i think. anyone know who uses that? i love my 414, just hate all that taping! i have been using straps, but just would prefer something more solid. thanks!!
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 03-03-2003, 08:02 AM   #2111
Pyramid's Avatar
I do not think Xray parts will fit perfectly for your matters. There is Japan company called RACY who makes that think you looking for. Unfortunately, I could not find it in stock anywhere (beside in Japan of course).
here is link to see how it looks like (go under 414M topic),
http://www.oct.zaq.ne.jp/nao-jun/
Pyramid is offline   Reply With Quote
Old 03-03-2003, 08:05 AM   #2112
Pyramid's Avatar
In case any fellow 414 users here have fortunate to compare TB EVO3 with 414M, please share your comments. Thanks in advance
Old 03-03-2003, 08:41 AM   #2113
mike f-
that is exactly what i have done
peter
Old 03-03-2003, 08:42 AM   #2114
Turbonium's Avatar
those are just what im looking for... anyone know where i can get those? i dont care if they have to come from japan, or whereever... could use a couple o sets. thanks!!!
Wes
Team Novak
Old 03-03-2003, 06:08 PM   #2115
imataquito's Avatar
Send a message via ICQ to imataquito Send a message via Yahoo to imataquito
hello guys anyone manage to try the SSG graphite convertion yet ??
i have 5 screws stuck on my 414m the head stripped and i cannot remove them anyone have any suggesion pls on how to remove it plz.. PLZ.. PLZZZZZZZ tell me ......
and i am using a proper hex driver .... not some al-cheapo ones
now my whole 4 front bulkhead screws is stuck and my front A-arms holder are also stuck due to 1 stripped screw
i was thinking of scrificing the graphite part and replace it with the SSg ones... would like some insight on how does the ssg compare to the original ones .....
and is there anyone using it yet ? ??
imataquito is offline   Reply With Quote
414x x414x R/C Items: Wanted to Buy 3 06-30-2010 11:17 AM
looking for a tamiya 414x subaru73 R/C Items: Wanted to Buy 0 06-07-2006 08:50 PM
Tamiya 414x meche R/C Items: For Sale/Trade 2 09-12-2004 06:25 PM
Tamiya 414X icon R/C Items: Wanted to Buy 6 10-02-2002 07:58 PM
Looking for a 414x,414m,or TB Evo grinch77 R/C Items: Wanted to Buy 0 07-24-2002 05:22 PM
