Old 01-17-2003, 04:53 AM   #1936
Vic
Vic's Avatar
Have you Guys tried Bigscaleracing simulator, is it any good?
Vic is offline   Reply With Quote
Old 01-17-2003, 06:55 AM   #1937
414M2 Tuning Aids
I will be racing this coming spring/summer on a smooth, high grip, realitively large parking lot surface. I will be using rubber tires (Sorex) with medium inserts.
My 414M2 came with a complete set of sway bars, but only a Yellow set of springs. I've read that some guys are using Associate springs (for whatever reason). Will the Tamiya spring set be sufficient for "most" track conditions?
Do you think that the new front upper sway bar is worth trying out?
Any other optional tuning parts I should consider?
Thanx
DEACON is offline   Reply With Quote
Old 01-17-2003, 07:24 AM   #1938
myclod's Avatar
Send a message via AIM to myclod Send a message via Yahoo to myclod
i have a guy that tried the assoc. springs on his 414 he didn't like them cuz they didn't fit QUITE right and it did effect his handling, he went back to Tamiya option springs and had no problems
myclod is offline   Reply With Quote
Old 01-17-2003, 08:30 AM   #1939
Casey's Avatar
I have been using Ass. springs with no problem, but you are right they are a little larger in diameter
Casey
Casey is offline   Reply With Quote
Old 01-17-2003, 08:10 PM   #1940
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Casey did you ever get new rear toe in blocks yet like you are looking for?
Old 01-18-2003, 02:42 AM   #1941
rccarracer's Avatar
Originally posted by jwwu
Here's a qn for all the TRF insiders and Ms. Cleo's among you...
Ok, so we know that Tamiya plans to release some really trick parts for the 414M sometime in February... anyone know/think Tamiya will release a new version of the 414M to include these new parts?
C'mon... somebody here's gotta know something!
(I'm thinking of ordering a while of hop-ups from Japan real soon... enough to substantially increase Japan's export figures... unless Tamiya plans to issue a new 414M. I would wait in that case...)
I've actually been wondering the same thing. Does anyone here have good friends within Tamiya Japan?
rccarracer is offline   Reply With Quote
Old 01-18-2003, 09:42 AM   #1942
Merciless's Avatar
Send a message via ICQ to Merciless
Default Springs
I have been using the X-Ray spring set with great success they are a perfect fit and come as a complete set
only thiy i should say is you may still want the ass. 40lb springs for the front if using foam tyres on carpet
Merciless is offline   Reply With Quote
Old 01-19-2003, 12:49 AM   #1943
TRF-Powered's Avatar
click on the link provided, you will be able to see SSG and lightweight bulkhead equipped M pretty cool~
http://www.oct.zaq.ne.jp/nao-jun/414m-2.htm
TRF-Powered is offline   Reply With Quote
Old 01-19-2003, 04:21 AM   #1944
hmm... where is it?
jwwu is offline   Reply With Quote
Old 01-19-2003, 07:08 AM   #1945
madjack's Avatar
Trader Rating: 20 (100%+)
Send a message via Yahoo to madjack
Default ssg chassis picture
here you go!
madjack is offline   Reply With Quote
Old 01-19-2003, 09:04 AM   #1946
any idea when the ssg chassis will be out??? i have some friends that are trying to get some stuff asap.. but not in time for the tcs in newark..
teamatlas is offline   Reply With Quote
Old 01-19-2003, 02:41 PM   #1947
Merciless's Avatar
Default Gear Ratio Chart
Don,t suspose ne1 can post one for me in 48dp ?
PLEASE thx,s guys
Old 01-19-2003, 02:46 PM   #1948
Slurp... yummy... thanks, madjack!
Old 01-19-2003, 04:26 PM   #1949
KiwiKid's Avatar
According to Rainbowten - release date is the end of Feb (pre-order only).
KiwiKid is offline   Reply With Quote
Old 01-19-2003, 04:58 PM   #1950
Deves's Avatar
Merciless, use this link: http://www.arroyoc.com/gear.asp
enter your pinion gear size and transmission ratio 2.133 for the TRF414M. Hope this helps, Deves
Deves is offline   Reply With Quote
414x x414x R/C Items: Wanted to Buy 3 06-30-2010 11:17 AM
looking for a tamiya 414x subaru73 R/C Items: Wanted to Buy 0 06-07-2006 08:50 PM
Tamiya 414x meche R/C Items: For Sale/Trade 2 09-12-2004 06:25 PM
Tamiya 414X icon R/C Items: Wanted to Buy 6 10-02-2002 07:58 PM
Looking for a 414x,414m,or TB Evo grinch77 R/C Items: Wanted to Buy 0 07-24-2002 05:22 PM
