Old 01-07-2003, 06:38 AM   #1861
Droop affects weight transfer...
Frictiion, and thus Traction, is a function of Weight...
Therefore, Droop affects traction...
Really, droop affects how far your chassis can roll in a corner. Chassis roll transfers weight from side to side. Droop also can affect how much weight is transferred from end to end during acceleration and braking. Any increase of weight on one tire results to increased traction for that tire.
TRF512 is offline   Reply With Quote
Old 01-07-2003, 09:28 AM   #1862
imataquito's Avatar
Send a message via ICQ to imataquito Send a message via Yahoo to imataquito
hm..... but i think say if u have 4mm front droop and 6mm rear droop then u cut the droop on both ends by 2mm
so u will ahve 2 mm front and 4 mm rear ...
wont u be cutting away all the traction u should have otherwise ??
i just dont understand how it will be better.......
i understand its a valuable tool in setting the on/off power stearing but ....
heh i guess i gota test it for myself ....
will ask if i have any questions
imataquito is offline   Reply With Quote
Old 01-07-2003, 06:07 PM   #1863
rough512's Avatar
Since you decreased the front droop, you also decreased the amount by which the front rises on acceleration. This results in lesser weight transferred FROM the front towards the rear (during acceleration). This means, you're keeping more weight on the front tires and you should have more traction as a result.
Decreasing the droop on the rear also prevents weight from transferring from the rear towards the front on deceleration. This translates to more traction on the rear so your tail don't go whipping around during cornering.
rough512 is offline   Reply With Quote
Old 01-07-2003, 08:32 PM   #1864
Casey's Avatar
Default Rear Hub Carriers
anyone know the part # of the 0 deg rear upright carrier
casey
Casey is offline   Reply With Quote
Old 01-07-2003, 09:44 PM   #1865
Aurra Sing's Avatar
Tamiya only makes 1 and 2 rear uprights.
1 Plastic Uprights: 50869
1 "Hard" Uprights: 53428
Aurra Sing is offline   Reply With Quote
Old 01-08-2003, 03:47 AM   #1866
imataquito's Avatar
ok will try to use less droop
Old 01-08-2003, 07:08 AM   #1867
Casey's Avatar
Thanks: Aurra Sing
Old 01-08-2003, 07:10 AM   #1868
Casey's Avatar
I was thinking of making my own Hinge pin blocks
Old 01-08-2003, 08:28 AM   #1869
madjack's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to madjack
Default US TOURING CAR CHAMPIONSHIPS
I resently spoke to some of the TRF drivers from the US and they received the EVO3 kit for use in the US TOURING CAR CHAMPIONSHIPS at S&N's Trackside Raceway & Hobbies, January 9th - 12th, 2003
It will be interesting to see how well they will fair without any testing time with the new car....or extra parts, guess the M2 will serve as a decent back-up car.
For real time race info. vist the Trackside site at:
http://www.trackside.com/
Best of luck to Dave and Jimmy!
http://groups.yahoo.com/group/tamiyatrf/
madjack is offline   Reply With Quote
Old 01-09-2003, 08:32 PM   #1870
Trader Rating: 62 (100%+)
Default front diff wear question
i replaced the front one-way w/a diff and metal outdrives. after about 6 mos, there seems to be excessive wear (see pic.) is this normal? im only running stock. are there steel outdrives available (the stock ones seem to be aluminum)? if i switch to delrin for the front, will it last longer? im under the impression that delrin is only for the rear because it may snap in a collision when used in front. thanks for any info
marvi is offline   Reply With Quote
Old 01-10-2003, 12:57 AM   #1871
Vic
Vic's Avatar
Go for the delrin outdrives I also had problem with the metal ones
never use them again.I had the dogbone stuck in that hole (like your picture shows) and I lost damping complitely.
Cheers
Vic is offline   Reply With Quote
Old 01-10-2003, 08:32 AM   #1872
madjack's Avatar
Default New 414M parts announced
Tamiya Japan announced new bulkhead and chassis parts for the 414M...they appear to be the same parts that Dave Jun designed and has been running on his car for the last six months.
Old 01-10-2003, 09:08 AM   #1873
Vic
Vic's Avatar
I wonder how expensive they will be!?
I suppose a little bit of do it ourself will get to almost the same result.
What do you Guys think?
Old 01-10-2003, 12:38 PM   #1874
They look very very nice i will be having a set when they come out. Rick
Rick Draper is offline   Reply With Quote
Old 01-10-2003, 01:48 PM   #1875
Default Pricing
49269 Tamiya --- TRF414M Lightweight Front Bulkhead 5,800
49270 Tamiya --- TRF414M Lightweight Rear Bulkhead 9,800
49271 Tamiya --- TRF414M Lightweight Motor Plate 1,500
49272 Tamiya --- TRF414M Carbon Upper Deck 1,600
49273 Tamiya --- TRF414M Carbon Lower Deck 6,000
49274 Tamiya --- TRF414M Damper Stay Front 1,200
It is due to come out 2/2003 in Japan. All prices are in Yen.
nolan_racing is offline   Reply With Quote
414x x414x R/C Items: Wanted to Buy 3 06-30-2010 12:17 PM
looking for a tamiya 414x subaru73 R/C Items: Wanted to Buy 0 06-07-2006 09:50 PM
Tamiya 414x meche R/C Items: For Sale/Trade 2 09-12-2004 07:25 PM
Tamiya 414X icon R/C Items: Wanted to Buy 6 10-02-2002 08:58 PM
Looking for a 414x,414m,or TB Evo grinch77 R/C Items: Wanted to Buy 0 07-24-2002 06:22 PM
SEO by vBSEO 3.5.0
