Old 12-27-2002, 07:15 PM   #1816
rough512's Avatar
I remember the post...
It said to heat the bulkhead slightly then tap out the bearing with a dowel.
The bearings are force-fitted into the bulkheads (?)
rough512 is offline   Reply With Quote
Old 12-27-2002, 07:40 PM   #1817
Aurra Sing's Avatar
Jimmy Jacobsen said that they are glued on!
Aurra Sing is offline   Reply With Quote
Old 12-27-2002, 11:20 PM   #1818
madjack's Avatar
Trader Rating: 19 (100%+)
Send a message via Yahoo to madjack
use the heat gun...and good luck!
http://groups.yahoo.com/group/tamiyatrf/
madjack is offline   Reply With Quote
Old 12-30-2002, 05:04 AM   #1819
TTT
Rick Draper is offline   Reply With Quote
Old 12-30-2002, 10:52 PM   #1820
imataquito's Avatar
Send a message via ICQ to imataquito Send a message via Yahoo to imataquito
can everyone send in pic of their cars rear end camber link positions ...???
have been experimenting and have some biggg questions about it ....
just wondering
imataquito is offline   Reply With Quote
Old 12-30-2002, 10:56 PM   #1821
Deves's Avatar
Hi, I'm new to this thread having just finished building my TRF414M2. I don't have any pics but my car is all stock right now. i'll be looking for any setup tips to enhance the performance of this car.
Deves is offline   Reply With Quote
Old 12-30-2002, 11:10 PM   #1822
rccarracer's Avatar
Glad you could join us with your 414M2, Deves....
If you need any help just ask, were all got a pretty good knowledge when it comes to the 414 series....
rccarracer is offline   Reply With Quote
Old 12-30-2002, 11:41 PM   #1823
imataquito's Avatar
what are the effects if i raise the link position on bulkheads on the rear?.
what about the front... ?
in the rear i usually use links angled downwords towords the chasis (
nospacers on bulkhead) and i will gain neg camber if the suspension is compressed.
i also experimented with parallel links in relation to lower A arms(added
spacer on bulkheads) ... and then i went to adding more spacers on the
bulkhead till the pivotal point on the bulkhead is much higher compared to
the one on the hubs...
i find that by doing so the rear end felt glued to the ground and i felt
much more confident with the car overall .... ( WIERD eh)
and by studying surikan's setting i figured that his cam- links must have
been set the same way or is it not ???
and what about the front end ?? what effect does it have ?
Old 12-31-2002, 02:42 AM   #1824
black-knight's Avatar
R/C Tech Charter Subscriber
Originally posted by imataquito
what are the effects if i raise the link position on bulkheads on the rear?. what about the front... ?
my answer: raising the rear or front "top inner mount point" will give you a lower roll center. where as lowing this link will give you a higher roll center.
the trick is to get the RC (roll center) of the car close to the chassis CG (center of gravity). the closer the the RC to the CG the less body roll will be exhibited , car will then corner "flat", allowing it to obtain and maintain good corner speed.
i suggest you grab a copy of XXX Main's Chassis Setup Guide by Martin Crisp, the guide covers all aspects of chassis setup inclusing roll center, and camber link adjustments. i have found the guide to be a very valuable tool...
on my 414worlds i do run extra spacing on the rear link and the result is more grip, i have also got rid of the front end anti dive (as in kit, for smooth tracks only), and added some kick up, this settles the car into corners, but gave me a little more steering on mid-exit. (depends on track as per usual). no front sway bar either.
i run modified classes, if running stock setup may be a little different...
Black-Knight - None shall pass!
www.nbhc.com.au - www.facebook.com/smaracing
black-knight is offline   Reply With Quote
Old 12-31-2002, 05:33 PM   #1825
imataquito's Avatar
hm...... removing antidive means removing the spacer on the bottom of the front A-arm holders right?? and how do u add kickup??
or did u mean that u removed anti squat and added caster?
confused
Old 12-31-2002, 05:39 PM   #1826
Does anyone know the poundage rating of the Tamiya springs?
Thanks in advance.
BOY-RCR is offline   Reply With Quote
Old 12-31-2002, 05:44 PM   #1827
confused
kickup is obtained by making the forward most "front" A-arm holder higher than the rearward front A-arm holder. (if it's lower you have anti dive.)
the angle of the hinge pins determines how easily weight is transfered, the angles resulting in anti dive resist weight to the front. (think of how anti squat works for the rear).
Old 12-31-2002, 05:56 PM   #1828
imataquito's Avatar
ok....
caster = antidive =kickup just that its effected by diff parts of the chasis ...
caster is the overall antidive and kickup u have .........
antidive is from the knuckles/hubs or upper arm mounting( on xray and corally i think )
and kickup is on the lower A-arm holders ............
thats what i tot in relation of full scale cars ...
Old 12-31-2002, 07:43 PM   #1829
Default 414 worlds stabilizer kit
i have 5 of these kits that i need to get rid of, asking $25 plus shipping. email me at nangha31@hotmail.com and let me know
blitz is offline   Reply With Quote
Old 01-01-2003, 09:54 AM   #1830
Default plastic outdrives
I just got a 414M2 and wondering about the durability of the plastic outdrives. Do they last long? Is this something that needs to be upgraded. Thanks.
nolan_racing is offline   Reply With Quote
414x x414x R/C Items: Wanted to Buy 3 06-30-2010 11:17 AM
looking for a tamiya 414x subaru73 R/C Items: Wanted to Buy 0 06-07-2006 08:50 PM
Tamiya 414x meche R/C Items: For Sale/Trade 2 09-12-2004 06:25 PM
Tamiya 414X icon R/C Items: Wanted to Buy 6 10-02-2002 07:58 PM
Looking for a 414x,414m,or TB Evo grinch77 R/C Items: Wanted to Buy 0 07-24-2002 05:22 PM
