Old 12-12-2002, 09:11 AM   #1756
So I should get the worlds swaybars kit, and rear toe blocks. Thanks!!
Also looking forward to those pics!
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 12-12-2002, 09:17 AM   #1757
reflekt's Avatar
Send a message via AIM to reflekt
someone always says they've put on those Xray battery straps and that they will get a pic up soon. but no one ever does...
i hope someone actually does this time...
reflekt is offline   Reply With Quote
Old 12-12-2002, 09:18 AM   #1758
reflekt's Avatar
another
Old 12-12-2002, 10:58 AM   #1759
Thanks REFLECT! Those look good! I see you use the original battery tape slots did you countersink them? Also dd you have to make the C/F straps or do the X-Ray pieces work?
Old 12-12-2002, 11:10 AM   #1760
I may try Schumacher posts with a custom strap.....HMMMM
Old 12-12-2002, 12:01 PM   #1761
rayhuang's Avatar
Does anybody know Derek Hung and how to e-mail him? he was in both my qualifiers at US Indoor Champs and was SOOO Fast with those Tamiyas!!! Would like to ask him a few questions!!!
Please shoot him this e-mail addy if you can: rshuang@ameritech.net
Thansk,
Ray
Old 12-12-2002, 12:20 PM   #1762
when you put these straps on, you must use epoxy the battery strap slot and then drill and countersink the screw hole for the xray posts, that way you will insure that you will not tweak the chassis. i will post some pics soon.
the toe in blocks are one of the most important things to buy for the 414
blitz is offline   Reply With Quote
Old 12-12-2002, 12:33 PM   #1763
reflekt's Avatar
from speedtechrc.com...
are u talking about these?
TAM53472 Tamiya TA04 Toe-In rear upright set
is that what ur talking about?
Old 12-12-2002, 07:41 PM   #1764
no reflekt
the part is called a suspension arm block and then it will have the letter c or d after it to differentiate from the degrees.
Old 12-13-2002, 11:53 AM   #1765
Default 414M2 dogbone/CV alternatives???
Are there any lightweight dogbone/CV's available for the 414M2 from Tamiya or another manufacturer (MIP, etc.)?
Also, is there a FAQ for the 414 series of cars? I'm mostly interested in learning what parts are interchangeable between the other Tamiya cars. This has probably been mentioned here, but there are so many post to page through, and without specific numbers the Search Engine dosen't help very much.
Concerning the parts, I'm specifically interested in know the part numbers for converting my 414M2 to full time 4WD (front diff & center).
DEACON is offline   Reply With Quote
Old 12-13-2002, 01:16 PM   #1766
black-knight's Avatar
R/C Tech Charter Subscriber
Default Re: 414M2 dogbone/CV alternatives???
You can use this part: Part # 53502 - 42mm Lightweight Rear (and Front) swing shafts. The have the number 42 prinited on them (39mm are for TA04)
All you need to go full time 4wd is a standard TA04 ball diff for the front and a std TA04 layshaft and center pulleys.
The part numbers are on the back of every set of instructions for the 414 or ta04 series.
Black-Knight - None shall pass!
www.nbhc.com.au - www.facebook.com/smaracing
black-knight is offline   Reply With Quote
Old 12-13-2002, 04:50 PM   #1767
Actually to convert the 414 to full time 4wd you can use a second fixed pulley like the one on the spur side, all you have to do is file a small slot on the one-way side for the set screw to lock into.
Old 12-15-2002, 09:57 PM   #1768
rough512's Avatar
Default Setting Wheels
Hi!!! what's the diameter of the Tamiya Setting Wheels?
rough512 is offline   Reply With Quote
Old 12-16-2002, 03:15 AM   #1769
rccarracer's Avatar
Just like to say I've finally found a TRF414X after some hard searching. NIB as well!!
Want to build it, but can't bring myself to......yet!
rccarracer is offline   Reply With Quote
Old 12-16-2002, 04:54 AM   #1770
Thumbs up Glad you found one.
I'll build it for you, since you can't
x414x is offline   Reply With Quote
414x x414x R/C Items: Wanted to Buy 3 06-30-2010 11:17 AM
looking for a tamiya 414x subaru73 R/C Items: Wanted to Buy 0 06-07-2006 08:50 PM
Tamiya 414x meche R/C Items: For Sale/Trade 2 09-12-2004 06:25 PM
Tamiya 414X icon R/C Items: Wanted to Buy 6 10-02-2002 07:58 PM
Looking for a 414x,414m,or TB Evo grinch77 R/C Items: Wanted to Buy 0 07-24-2002 05:22 PM
