Old 12-03-2002, 07:17 PM   #1696
Casey's Avatar
Vic,
with the rear links on the tower, this lets there be more camber gain when the suspension compreses, and with foam tires this keeps the tires from rollimg on the outer edge,
This placement keeps the tire flat through the compression of the rear arms
Casey
WYD,
The protoform BMW is nice......
Casey is offline   Reply With Quote
Old 12-03-2002, 07:41 PM   #1697
Jack's Avatar
I have been using the vauxhall body for some time now.. n i kinda of perfer it over the stratus...
give you good downforce and steering.
Jack is offline   Reply With Quote
Old 12-04-2002, 12:01 AM   #1698
reflekt's Avatar
Send a message via AIM to reflekt
i was wondering...
do these yokomo bodies come with those headlight stickers? or do we have to paint them in?
The stratus bodies, specifically the "new style stratus" and the "type d" bodies.
Also, if u notice in the second row of pictures, the yokomo stratus body has those head lights again here: http://www.oct.zaq.ne.jp/nao-jun/
are those stickers? or painted in? thanx.
reflekt is offline   Reply With Quote
Old 12-04-2002, 12:03 AM   #1699
reflekt's Avatar
oops, forgot to give link...
http://64.70.208.72/speedtechrc/3.html
the yokomo bodies here. stickers? or painted headlights?
also, for speedtechrc..
do the yokomo stratus bodies come with stickers, window masking sheet, and wing mounting hardware, etc?
Old 12-04-2002, 01:04 AM   #1700
Merciless's Avatar
Send a message via ICQ to Merciless
Default Hi all
just thought i should say hi so you all know i,m still alive
Get to race again friday....made some set-up changes and i,ll post saturday how it all went
Merciless is offline   Reply With Quote
Old 12-04-2002, 01:51 AM   #1701
Merciless's Avatar
Default THE ONE-WAY FRONT DIFF
What r your views on running this,or the center one and or the pair at once,like the worlds kit.
At present i,ve got both in(mainly cause i ain,t bought the fixed center one yet).
i run on carpet with foams and have found it to be better with past cars to run the front one-way but always disabled the center one :+) !!
Old 12-04-2002, 07:17 AM   #1702
Default Re: Re: Pathetic
Originally posted by rough512
Is the TA03 steering knuckle compatible with the 414X?
Some guy who works for Tamiya told me the alloy knuckles were the same and from pictures they appear to be.
x414x is offline   Reply With Quote
Old 12-04-2002, 12:06 PM   #1703
rtypec's Avatar
Anybody notice their spur gear wobble due to spur hub/layshaft being out of allignment?
rtypec is offline   Reply With Quote
Old 12-04-2002, 12:09 PM   #1704
Merciless's Avatar
Default Wooble
Would guess that down to poor spur gear before i looked any further m8
try an RW one machined nylon and very good
Old 12-04-2002, 12:12 PM   #1705
rtypec's Avatar
Ummm yeah, all I ever run are RW spurs and Ti Racing pinions and they are always round. It's just that my hub or perhaps the layshaft could be off. I even tried a 404 spur hub and there is still wobble. I'll see what I can do. Guess I was spoiled with my Xray's precision.
Old 12-04-2002, 12:33 PM   #1706
reflekt's Avatar
i used to have this problem of the spur gear wobbling side to side and not staying in place. but all u have to do is unscrew the hex from the center pulley and also the loosen the spur gear hub. then, pull the spur gear w/the hub towards the center pulley as much as u can, then tighten down the spur gear. next, just pull the center pulley towards the spur gear as much as u can, then tighten that. this should get rid of the play u might have with the spur gear wobbling left to right.
BTW, does anyone have an answer to my previous question? about the yokomo bodies? stickers or painted in?? peaches.
Old 12-04-2002, 12:36 PM   #1707
rtypec's Avatar
Thanks for the info. The Spur does not wobble vertically, as seen from above. It wobbles when you look at it head on, as if the spur is not perfectly rount. I remove the spur and you can see a small wobble on the spur hub.
Also, I have seen Yok bodies in the store and they come with stickers for the lights. However, there are people out there who airbrush their own designs.
Old 12-04-2002, 12:41 PM   #1708
reflekt's Avatar
so ur saying that ur spur gear doesn't slide left to right? but instead it actually wobbles off the pinion? if this is true. dont u hear a sound when u run ur car? like a chronic sound that happens everytime u turn ur wheels one rotation. if this is the case, it's probably ur spur gear. maybe one or a few of ur teeth have been screwed. but if it indeed is ur spur hub, i suggest trying someone else's hub at the track and see if it still wobbles. but anyway..
so the yoke stratus bodies come with those exact light stickers? or are they diff? thanx. peace.
Old 12-04-2002, 01:52 PM   #1709
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
reflekt the Yokomo C body has two different front headlights you can use. It also has all the normal decals for tail lights and other feathures. The body has the protective film on the outside to prevent overspray and has window cutouts as well. I have one on my Yoke.
Jack that is cool about teh Vauxhall. Just sick of the Stratus as I have had them for the last 3 years now.
Casey I will have to get a BMW as well. I do like the looks of Beamer. I think the Vauxhall will work great. I looked last night at my Stratus 2.0 and my new Vauxhall and the Vauxhall sits a fair amount lower and tighter on the car. It seems to be very low profile. I'm ready to run it on Saturday to see how it goes.
Old 12-04-2002, 07:50 PM   #1710
just giving this a shot....have you look at the bearings on the bulkhead which is holding the center shaft?
fReShJiVe is offline   Reply With Quote
414x x414x R/C Items: Wanted to Buy 3 06-30-2010 11:17 AM
looking for a tamiya 414x subaru73 R/C Items: Wanted to Buy 0 06-07-2006 08:50 PM
Tamiya 414x meche R/C Items: For Sale/Trade 2 09-12-2004 06:25 PM
Tamiya 414X icon R/C Items: Wanted to Buy 6 10-02-2002 07:58 PM
Looking for a 414x,414m,or TB Evo grinch77 R/C Items: Wanted to Buy 0 07-24-2002 05:22 PM
