Old 12-02-2002, 04:33 AM   #1681
Vic
Vic's Avatar
Hi,
Anybody can help me!
If you use an aluminum ball differential instead of the original plastic and want to replace the teflon "spacers" or "ball holders" (I don't know what you call them)where can you get them separately or what can you use instead?
Thanx in advance!!
Vic is offline   Reply With Quote
Old 12-02-2002, 08:00 AM   #1682
Originally posted by Vic
Hi,
Thanx in advance!!
I can help. It's called ball diff bushings. You get 20 for 1.20USD from Tamiya America.
3459075 Ball diff bushing
http://www.tamiyausa.com/contact.html
x414x is offline   Reply With Quote
Old 12-02-2002, 08:07 AM   #1683
Vic
Vic's Avatar
Thanx!
I appreciate it!
Old 12-02-2002, 09:52 AM   #1684
rtypec's Avatar
Default 414WCR Chassis Number 0001/1700 in Action
Well guys, just when you thought that chassis number one would be in a museum somewhere in Japan, guess what showed up at the track this Saturday ? Chassis 0001/1700 Hmmm...one screw for the spur hub, two for the motor, and three the motor plate, I'll trade you motor plates Taka cuz mine will make you go faster hahaha. Here's a pic of Taka and chassis one in action.
rtypec is offline   Reply With Quote
Old 12-02-2002, 10:01 AM   #1685
Casey's Avatar
Vic,
Glad it worked for you, I actually ran a liitel kick up in the front this weekend to get the car to cut in a little harder,
But i think I like it the way before
Casey
Casey is offline   Reply With Quote
Old 12-03-2002, 12:23 AM   #1686
Vic
Vic's Avatar
Casey,
One question what difference does it make in theory if I attach the rear upper links to the tower instead of the bulk-head?
Old 12-03-2002, 08:10 AM   #1687
SpeedTech's Avatar
reflekt,
The titanium turnbuckles from Tamiya comes in pairs, and it uses a square instead of a hex as adjustment nut. Using Tamiya turnbuckles allow you to stay TCS legal We also have the 5.5mm spacer kit, which allow you to adjust the roll center of the 414M2 I believe.
rtypec,
if you're going to SoCal, bring spare parts!
Steve Wang
Speed Tech R/C
www.speedtechrc.com
SpeedTech is offline   Reply With Quote
Old 12-03-2002, 09:11 AM   #1688
Default Pathetic
Here's my 414X.... Pretty lame, ehh?
I'm in desperate need of...
*Rear 414X/414 Bulkheads
*Blue Tamiya Setting Wheels (414 Silvers for trade)
*Ta03/414X Alloy Steering Knuckles
Old 12-03-2002, 09:13 AM   #1689
Default Re: Pathetic
Pic (as if it mattered).
Old 12-03-2002, 10:54 AM   #1690
reflekt's Avatar
Send a message via AIM to reflekt
oooooooooooooooh....
berry nice. good luck with finding ur parts. hiro doens't have'em??? if he doens't have them...who does?? peaches.
reflekt is offline   Reply With Quote
Old 12-03-2002, 10:55 AM   #1691
reflekt's Avatar
btw,
thanx SPEEDTECH for the info! i think i'll get myself some titanium turn.'s. peaches.
Old 12-03-2002, 10:59 AM   #1692
reflekt's Avatar
Originally posted by SpeedTech
reflekt,
rtypec,
Steve Wang
Speed Tech R/C
www.speedtechrc.com
one question...
i was wondering, the steel turnbuckles that come with the TRF414M2 kit are 7 3x38mm turnbuckles and 2 3x18mm steering linkage turnbuckles. now....
the 3x18 i can get with just a pair. but the 3x38mm turnbuckles? speedtech, u guys only sell 3x32 and 3x35? would either size work? or do i have to get 3x35mm to replace the stock 3x38mm turnbuckles?
also, can i just save myself a buck and get the cheaper 3x32mm turnbuckles? or do i have to get the 3x35mm ones? let me kno. thanx. peaches.
Old 12-03-2002, 05:21 PM   #1693
rough512's Avatar
Is the TA03 steering knuckle compatible with the 414X?
rough512 is offline   Reply With Quote
Old 12-03-2002, 05:49 PM   #1694
TRF-Powered's Avatar
Originally posted by reflekt
one question...
35mm works just fine!
TRF-Powered is offline   Reply With Quote
Old 12-03-2002, 06:15 PM   #1695
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Anybody run the Protoform Vauxhall body on their 414M2? I wanted something other than the 2.0 Stratus that I do run most of the time. I looks alot like the Protoform Primera body that I ran a few years ago from Protoform. I think the Vauxhall should be a nice neutral body with good steering and good downforce. It is very sleek fitting on my 414. It looks good too!!!!
414x x414x R/C Items: Wanted to Buy 3 06-30-2010 11:17 AM
looking for a tamiya 414x subaru73 R/C Items: Wanted to Buy 0 06-07-2006 08:50 PM
Tamiya 414x meche R/C Items: For Sale/Trade 2 09-12-2004 06:25 PM
Tamiya 414X icon R/C Items: Wanted to Buy 6 10-02-2002 07:58 PM
Looking for a 414x,414m,or TB Evo grinch77 R/C Items: Wanted to Buy 0 07-24-2002 05:22 PM
