Like Tree2Likes
Old 11-29-2002, 11:48 AM   #1666
Casey's Avatar
I tried mounting them up, they look to be a little loose, in the mounts...
Casey is offline   Reply With Quote
Old 11-29-2002, 03:31 PM   #1667
Merciless's Avatar
Send a message via ICQ to Merciless
Default Sway Bars
Casey
i used to have a similar view to the sway bars as you when i ran my x-ray early on (good set-up didn,t need them,hard springs worked well)
but after adding them i found i could get around the corners even faster,set-up needs to be good tho add i would suggest using using 1 to 2 grades softer on the rear than the front
i also find on carpet using the shocks mounted as upright as possible good(car changes direction faster,more responsive) do you have any thoughts on this ?
Merciless is offline   Reply With Quote
Old 11-29-2002, 05:42 PM   #1668
Casey's Avatar
yes, standing up the shocks, decrease side bite lets the car pop through the cornor
Casey
I will try the sway bars Sat.
Old 11-29-2002, 06:32 PM   #1669
Pyramid's Avatar
Default Re: Rear Arm Pic
Originally posted by Merciless
should have been attached to last post sorry guys
Yes, that's two closed holes on the bottom of upright. If you looking to adjust 1 deg, I do not think you could do it. But as for 0.25deg or 0.5deg maximum should be ok to achived.
Other thing to try, dismantle all rear bulkhead and try to rebuilt with bulkhead screwed first then the suspension arm.
Pyramid is offline   Reply With Quote
Old 11-29-2002, 07:12 PM   #1670
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Hey Casey I ran the 414M2 tonight at RCO. IT was really good once I took the one ways out of my car. It then just kept getting better and better.
I use the bulkheads to mount my rear and front camber links. It has spacers under them now. What happens if I would use higher spacers/or lower ones. If I use no spacers will it give the car more or less traction at that end of the car?
Old 11-29-2002, 09:45 PM   #1671
SpeedTech's Avatar
Hi Guys,
We have the new World's front sway bar kit (with new arms) available online. Also, all the titanium turnbuckles are available now too.
Steve Wang
Speed Tech R/C
www.speedtechrc.com
SpeedTech is offline   Reply With Quote
Old 11-29-2002, 10:02 PM   #1672
fabolousRC's Avatar
Send a message via AIM to fabolousRC Send a message via Yahoo to fabolousRC
I don't know whether my set up is comparable to P2K setup but I use 40/122 (64p) on my P2k2 pro and it's still begging me to gear up!
Originally posted by mugenracer
what gearing is everyone using on the 414 with a stock p2k?
Tamiya DB01 Durga\Kyosho Lazer ZX-5\Kyosho Turbo Optima
Lex Tyler Paints \ Norcal Hobbies \ Bay Area Peninsula R/C Club
fabolousRC is offline   Reply With Quote
Old 11-29-2002, 10:18 PM   #1673
Aurra Sing's Avatar
I use 120/37-39 on my P2K2 depending on track. Works well.
Aurra Sing is offline   Reply With Quote
Old 11-29-2002, 10:22 PM   #1674
reflekt's Avatar
Send a message via AIM to reflekt
Originally posted by SpeedTech
Hi Guys,
Steve Wang
Speed Tech R/C
www.speedtechrc.com
hey, now wait a sec,
do the titanium turnbuckles come in TWO? or are they just...say for example $10.99 for just one turnbuckle? cuz if thats teh case, thats MAD expensive and i'd rather get lunsford for 5 bucks each.
reflekt is offline   Reply With Quote
Old 11-29-2002, 10:51 PM   #1675
Aurra Sing's Avatar
??? My LHS has Lunsford turnbuckles for $2 each.
Old 12-01-2002, 10:27 AM   #1676
Merciless's Avatar
Default Information needed
Have any you you found good web sites with information on the 414 or other good forums dedicated to it ?
This is the only good resource i have been able to find on it
And since i,m the only guy running one in my area i look to the web and yourselves for all the help with it i can
Old 12-01-2002, 05:39 PM   #1677
Pyramid's Avatar
Try this:
http://www.oct.zaq.ne.jp/nao-jun/
Old 12-01-2002, 07:53 PM   #1678
rtypec's Avatar
Default Hi Roll Center Strength Question
I know that a number of you have done the hi-roll center setup for your 414's. Has anybody noticed wether or not the car maintains its durability from the modifications? I'm curious to know as I'm about to use my car at one of the nation's most notorious chassis breakers errr I mean race tracks, SoCal (where novices are intermediates, intermediates are sportsman, and sportsman are pro stock ). A couple of buddies of mine are freaking me out.
rtypec is offline   Reply With Quote
Old 12-02-2002, 03:36 AM   #1679
Merciless's Avatar
Default Nice Site
Just a shame i can,t understand any on the writing
don,t suspose you want to do a translation Pyramid
Old 12-02-2002, 04:28 AM   #1680
Vic
Vic's Avatar
Cool
Casey,
I tried your set-up over the week-end and it was working really well!
Thanx4
Vic is offline   Reply With Quote
414x x414x R/C Items: Wanted to Buy 3 06-30-2010 11:17 AM
looking for a tamiya 414x subaru73 R/C Items: Wanted to Buy 0 06-07-2006 08:50 PM
Tamiya 414x meche R/C Items: For Sale/Trade 2 09-12-2004 06:25 PM
Tamiya 414X icon R/C Items: Wanted to Buy 6 10-02-2002 07:58 PM
Looking for a 414x,414m,or TB Evo grinch77 R/C Items: Wanted to Buy 0 07-24-2002 05:22 PM
