Old 11-27-2002, 08:18 PM   #1636
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Casey did you get my email? When are you coming to RCO again or are you a carpet guy again?
Are you running a Stratus on your 414M2? If so what one are you running?
Later
WYD
Old 11-27-2002, 08:33 PM   #1637
Casey's Avatar
just wrote back to you, I have a few big carpet races this winter, I like the Tamiya so much that I am running that instead of my trusty TC3
casey
do you have AOL IM ?? mine is OPALCL
Casey is offline   Reply With Quote
Old 11-28-2002, 12:34 AM   #1638
Merciless's Avatar
Send a message via ICQ to Merciless
Default TRUE worlds set-up
This is why you flip the block over so the belt passes under the block.....
Only do this when it is at a height around the "true" worlds setup...
[/QUOTE]
anyone got the TRUE worlds set-up ??
just asking
Merciless is offline   Reply With Quote
Old 11-28-2002, 01:45 AM   #1639
What happens if no spacers at all were inserted below the blocks, would the traction be very very good?
jenny is offline   Reply With Quote
Old 11-28-2002, 01:47 AM   #1640
ijnek's Avatar
Send a message via ICQ to ijnek
tat would depend on ur car's overall setting also...
all the settings r related,springs,droop,kickup etc,...in some way or another,they r related...
ijnek is offline   Reply With Quote
Old 11-28-2002, 06:18 AM   #1641
Casey's Avatar
Jenny, you are correct, if no spacers are in the roll center is low, therefore providing the lowest CG for weight transfer, that means traction,
If you guys have Extreme RC car magazine look up issue # OCT 2001 pg 90
Old 11-28-2002, 06:34 AM   #1642
wyd
Tech Legend
wyd's Avatar
Casey are you running saddle packs in your M2? I did the mods to run saddle packs. I think it is alot better that way.
Old 11-28-2002, 06:40 AM   #1643
Casey's Avatar
yep
Old 11-28-2002, 06:48 AM   #1644
wyd
Tech Legend
wyd's Avatar
Casey are you running the new yellow rimed TRC tires and if so do you trim the back of them so they don't run on the front ball ends? Mine just barely hit and will trim the ball ends a little and also the back of the rims some. Not a big problem and I'm glad as most cars are setup for rubber tires and since they are narrower the rims never rub.
Old 11-28-2002, 07:01 AM   #1645
Pyramid's Avatar
Default Re: Tamiya inc.
Originally posted by Merciless
Anyone got an e-mail adress for them
support section would be great
checked all my hindge pins etc and i still can,t sort out the rear tow-in
i,ve checked it and checked it again and it,s still 2 deg on 1 side and 3 on the other
i now feel completely sure it,s gotto be a chassis drilling fault however unlikely it is !!
On a car costing this much i must say i,m more than alittle disapointed
Cheapest solution:
Notice there are 2 kind of holes in the rear knuckle/uprights? (uprights with bearing's face facing you). Drill those two until you have acces to suspension shaft, no need all the down to the other side. Now put pinion kind of screw and adjust (tighten one, loosen the other) them until left and right suspension toe-in are at the same amount. This method also solve some sloops problems around rear uprights. Yes, your susp. shaft will have mark for screw but it wont matter.
About the worlds setup, It's very stable on most ashpalt. I do urge you to try it, just do not forget to dremel the susp. arms to where they will touch oneway joint cup for front or the delrin cup for rear.
Pyramid is offline   Reply With Quote
Old 11-28-2002, 07:13 AM   #1646
Vic
Vic's Avatar
Can anybody post this mistique WC set-up?
I am considering of buying a serious ESC any suggestions!
I can put my hands on a GM V12 for a good price?!?!
Vic is offline   Reply With Quote
Old 11-28-2002, 07:16 AM   #1647
Merciless's Avatar
Default Tow-in
Can you post a picture or try to explain again ?
sorry i don,t fully understand what your saying for me to do
Old 11-28-2002, 07:26 AM   #1648
Merciless's Avatar
Default speedo
i,ve got a m.tronics cube very small very good
m8 uses the new novak and that is very good also
Pic inc. you you can get a feel for the size of the cube (it,s very small indeed).I,ve run it with motors down to a 2x8 on high grip carpet so it was pulling some amps through that poor speedo
Old 11-28-2002, 10:39 AM   #1649
Casey's Avatar
I use Jaco stuff
I also space out the tires with those little HPI hex spacers
Old 11-28-2002, 02:45 PM   #1650
Merciless's Avatar
Default Hi all
Casey ,
Have you got a good carpet set-up you can share with us ?
OR anyone else for that matter, i need carpet with foam tyre set-up
Anyone made any mods to there cars ?
Anyone got this ellusive Worlds set-up ?
Anyone got any other tips about the 414 you care to share??
414x x414x R/C Items: Wanted to Buy 3 06-30-2010 11:17 AM
looking for a tamiya 414x subaru73 R/C Items: Wanted to Buy 0 06-07-2006 08:50 PM
Tamiya 414x meche R/C Items: For Sale/Trade 2 09-12-2004 06:25 PM
Tamiya 414X icon R/C Items: Wanted to Buy 6 10-02-2002 07:58 PM
Looking for a 414x,414m,or TB Evo grinch77 R/C Items: Wanted to Buy 0 07-24-2002 05:22 PM
