Old 11-26-2002, 11:44 PM   #1621
rccarracer's Avatar
sengming, his car is the Worlds replica 414M, meaning they come as they look in the pic.....
They are fluorine coated.
rccarracer is offline   Reply With Quote
Old 11-27-2002, 01:26 AM   #1622
Merciless's Avatar
Send a message via ICQ to Merciless
Default Dampers
fluorine coated DUDE
the car comes all boyed up
Merciless is offline   Reply With Quote
Old 11-27-2002, 01:56 AM   #1623
Vic
Vic's Avatar
Talking
Hi,
Can any of you Guys exp0lain to me in details, what effects does it have if I put spacers under the rear upper arms or the front tourqe rods. I am kind of lost on this!
Thanks in advance!
Vic is offline   Reply With Quote
Old 11-27-2002, 01:58 AM   #1624
reflekt's Avatar
Send a message via AIM to reflekt
apparenly, it can make or break ur steering to an extent. i did what aurra did on his set up, tried it on the track, and i hav awesome steering/handling. my car is planted to the ground. I still feel it could be a little more dialed in. but right now, my car is pretty glued to the track.
reflekt is offline   Reply With Quote
Old 11-27-2002, 02:04 AM   #1625
reflekt's Avatar
didnt kno if i "had" to mention as well but of course...the anti squat, roll center, etc can help too. putting spacers under the blocks
Old 11-27-2002, 02:11 AM   #1626
Vic
Vic's Avatar
Can you tell me what is this set-up?
Old 11-27-2002, 02:26 AM   #1627
reflekt's Avatar
basically i have..
front upper links: 1mm
rear upper links : 5mm
FF: 0.7mm
FR: 2mm
RF: 3mm
RR: 2mm
outer most hole for shock body positions. i think i might move a hole in or two. see how the car runs with those setups. but right now, the car seems pretty dialed in at my track. peaches.
Old 11-27-2002, 02:38 AM   #1628
Vic
Vic's Avatar
Thanx!
What my problem is I understand the end result but I am lost with the details.
Therefore my question is:What happens if I put small or large spacers to the front and the same changes go to the back?
Old 11-27-2002, 09:36 AM   #1629
Aurra Sing's Avatar
Note that reflekt's setup is for an asphault track (So Cal.)
I heard a lower roll center (less spacers overall) is optimal for carpet, but I still haven't tried carpet personally.
A higher roll center in the rear (more spacers in rear) will give you more mid-corner steering, gentle turn-in. Higher roll center in front will give you more turn-in.
Aurra Sing is offline   Reply With Quote
Old 11-27-2002, 10:22 AM   #1630
Merciless's Avatar
Default Guess who,s got a new camera ?
My 414m worlds and dad,s X-ray
Old 11-27-2002, 10:40 AM   #1631
Merciless's Avatar
Default Tamiya inc.
Anyone got an e-mail adress for them
support section would be great
checked all my hindge pins etc and i still can,t sort out the rear tow-in
i,ve checked it and checked it again and it,s still 2 deg on 1 side and 3 on the other
i now feel completely sure it,s gotto be a chassis drilling fault however unlikely it is !!
On a car costing this much i must say i,m more than alittle disapointed
Old 11-27-2002, 10:44 AM   #1632
reflekt's Avatar
right now, i only have a few spacers underneath the suspension blocks. i'm going to add more and increase the height, for the roll center later on. but that requires dremeling/shaving of the rear arms a little bit. but for now, this setup is good to me. i'm sure if i did increase the height, it would give me even better handling. some guys at the track have their blocks high on spacers. some 5mm/4mm and some even 6mm/4mm (Rear). peaches.
Old 11-27-2002, 11:16 AM   #1633
Casey's Avatar
The higher you raise the blocks the more it decreases traction, to a point, be carefull on the front cuase the belt will hit the block.
Casey
Casey is offline   Reply With Quote
Old 11-27-2002, 06:19 PM   #1634
rccarracer's Avatar
Casey
This is why you flip the block over so the belt passes under the block.....
Only do this when it is at a height around the "true" worlds setup...
Old 11-27-2002, 08:16 PM   #1635
Casey's Avatar
you are correct sir, I was wondering if I go any higher, would I dremmel the block or flip it, thatk you for setting me straight, before I cut the block in half !!
414x x414x R/C Items: Wanted to Buy 3 06-30-2010 12:17 PM
looking for a tamiya 414x subaru73 R/C Items: Wanted to Buy 0 06-07-2006 09:50 PM
Tamiya 414x meche R/C Items: For Sale/Trade 2 09-12-2004 07:25 PM
Tamiya 414X icon R/C Items: Wanted to Buy 6 10-02-2002 08:58 PM
Looking for a 414x,414m,or TB Evo grinch77 R/C Items: Wanted to Buy 0 07-24-2002 06:22 PM
SEO by vBSEO 3.5.0
