Like Tree2Likes
Old 11-25-2002, 05:10 PM   #1606
Aurra Sing's Avatar
Wyd - no, you do not need to buy another center one-way unit to convert to locked center. Rather, you can just purchase a single aluminum center pulley, part #53474. I recommend one o-ring inside the shock.
Aurra Sing is offline   Reply With Quote
Old 11-25-2002, 05:35 PM   #1607
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Thanks for that part number. That pulley looks like a TA03 alum pulley. I will have my shop order that part number for me. That is a real big help to me and alot of money saved. Now I will just build a new diff so then I have it and if I need to take the one way out I can do so.
Old 11-25-2002, 06:18 PM   #1608
Default Carpet Set-up
Front:
Oil tamiya 60wt
yellow spring
yellow sway bar
shock mount middle hole
Rear:
Oil tamiya 50wt
yellow spring
red sway bar
Tires
Sorex 28R front
Sorex 24R Rear
Thats all i can tell you, my set up works since last time i went out i took sportsman class and the other time i TQ'd
Chris@WeaponR is offline   Reply With Quote
Old 11-25-2002, 06:18 PM   #1609
rccarracer's Avatar
Looks like but isn't.....different shaft diameter.
rccarracer is offline   Reply With Quote
Old 11-25-2002, 07:02 PM   #1610
rough512's Avatar
Also, the flange (is it the correct term) in the TA03 pulley is not fixed to the pulley. The pulley posted above is a single unit.
rough512 is offline   Reply With Quote
Old 11-25-2002, 08:53 PM   #1611
Casey's Avatar
WYD use the part # above that is the one, I use a reg front diff, and the one way center, that keeps it consistent.
Tamiya built this car to compete in the World Cup of racing, therefore rubber tires, That car has a ton of rear traction, and the key it to let the back of the car rotate the center of the cornor,
Ok here goes,
first off, I raised the roll centers, 3mm of spacers in the front on the hinge pin blocks, they are level
In the rear I run Pro Squat, 3mm in the back block and 2 mm in the front block, causing the arm to sweep forward,
I don't have any spacers in the shocks, just use the droop screws, this is a great tool to fine tune traction as said above
I ran the car in stock for the first week, so you know how many TC3;s are down here, I just has cornor speed , and that is were it is all at, I can gear or bulid motor for the boring straight
Front,
60 wt oil
Purple Ass. springs
Middle hole on the tower
camber link on the bulk head with out the 2mm spacer
Jaco purp/orange tires
Rear
45 wt.
Copper Ass. spring
Camber link in the bottom outer hole on the tower
Jaco purp tires on rear
It may sound weird, but the car floats through the cornor, and is not loose
Casey is offline   Reply With Quote
Old 11-25-2002, 10:29 PM   #1612
foampervert's Avatar
Send a message via MSN to foampervert
Default abt the short wheel base tao4.....
Originally posted by marvi
do you know the part nos.? thanks do i have to get both front and rear sets? also, with the shortened wheelbase using the canted arms, will the CVD's be at an angle? if yes, will this affect drivetrain efficiency or increase wear?
only the rear arms are different. the part number is : 50942 TA04-SS D Parts (Suspension Arm) everything else remains the same...drive shafts,diffs, belts,driver....... the wheelbase is only shortened by approximately 1cm++ so efficiency doesn't seem affected.wear rate seems fine too.
the car becomes slightly twitchy and seems to be able to take tight infields better.this suspension mode can also be used with any car using the tao4/414 type suspension and works similarly on any of these cars.can't get enough steering on 414 or tb? try these arms!
During heats, i use durex for both front and rear, with Hard inserts.
Sorex, i meant Sorex.
foampervert is offline   Reply With Quote
Old 11-26-2002, 07:14 AM   #1613
Trader Rating: 64 (100%+)
thanks ill look for that part in our lhs and try out the short wb. one more question: are there aftermarket short wb bodies available or is it only the tamiya mr2?
marvi is offline   Reply With Quote
Old 11-26-2002, 08:31 AM   #1614
imataquito's Avatar
Send a message via ICQ to imataquito Send a message via Yahoo to imataquito
Casey... i am interested on the way u set the car with the rear a arms sweeping foward ...... care to explain what are the difference compared to switching the 3mm and 2 mm around ..
shorter arms ??
well just move the spacers on the A arm around to minimize the lenght of the suspension....
and yea i am still looking for extra stearing and corner speed
imataquito is offline   Reply With Quote
Old 11-26-2002, 09:16 AM   #1615
Casey's Avatar
On the rear hinge pin mounts I have the front block at2 mm and the rear at 3mm,
I know a few of the TC3 and Losi factory guys are running pro squat, what this does is lets the car enter the cornor quicker, and rotate through the center quicker,
Before I made the change I was runing about 16.2 second laps, on a very tight twisty track,
Then when I got the arms to sweep forward I dropped to 15.9 ssec laps, It just helps the car glide , and carry speed throught the cornor.
Old 11-26-2002, 09:45 AM   #1616
Aurra Sing's Avatar
Default TA04SS arms on 414M
Note that because the arms are pushed forward 1cm, the driveshaft will be at an extreme angle. You could lose some drivetrain efficiency.
Old 11-26-2002, 10:35 AM   #1617
Merciless's Avatar
Send a message via ICQ to Merciless
Default Tow IN
Anyone checked the rear tow-in on there 414 worlds rep ?
just checked mine and one side is 2 deg and the other is 3deg ??
this is fixed by the rear/front blocks i tried turning 1 block at a time upside down to see if i could find a compramise but to no avail !!
i think my chassis must be drilled incorrectly !
Merciless is offline   Reply With Quote
Old 11-26-2002, 11:06 AM   #1618
Merciless's Avatar
Default Pics
me CAR
Old 11-26-2002, 02:53 PM   #1619
Casey's Avatar
Merciless
you could have a bent axle, or a bent rear arm?? I would check that ... just a thought
Old 11-26-2002, 03:36 PM   #1620
hey merciless, nice car man!!!
did your trf dampers come in fluorine coated or blue?
thanks
sengming is offline   Reply With Quote
414x x414x R/C Items: Wanted to Buy 3 06-30-2010 11:17 AM
looking for a tamiya 414x subaru73 R/C Items: Wanted to Buy 0 06-07-2006 08:50 PM
Tamiya 414x meche R/C Items: For Sale/Trade 2 09-12-2004 06:25 PM
Tamiya 414X icon R/C Items: Wanted to Buy 6 10-02-2002 07:58 PM
Looking for a 414x,414m,or TB Evo grinch77 R/C Items: Wanted to Buy 0 07-24-2002 05:22 PM
