Old 07-28-2003, 10:06 PM   #16
Randy Caster's Avatar
Trader Rating: 45 (100%+)
BagofSkill is inspiring me to get the IRS board I'm gonna have to try it out, pretty sure I can get the car much more fine tuned with it.
Old 07-29-2003, 03:57 PM   #17
Fine, I go out and I just got the Integy unit, it comes with three very nice machined stands. You can use two or four units if you believe it's going to be more accurate or faster. I tweak my car within a few minutes, making sure the cross weight is the same Rear Front +Left Rear = Left Front +Right Rear. The fact is it's not as time consuming as most of you think. The unit comes with calculation worksheets which really helps the whole process. Also I end up with 52.2% left and 47.8% right weight distribution, I run a Losi XXX-S (I mill everything out, it's about 2.5 ounce under legal weight) and I probably can't make the left and right even unless I won't to add weight to the right side. It brings up another interesting point, I think I may not want 50% cross weight afterall. Since my car's left side is heavier, that means left corner is going to be smaller and turn right might push a little. I'll play with it somemore at the track and see how it goes. If the theory is right, the right front and left rear wheels needs a little more spring tension if the car's left side weights more.
RickyIS300 is offline   Reply With Quote
Old 07-29-2003, 11:10 PM   #18
PizzaDude's Avatar
Thanks Ricky
PizzaDude is offline   Reply With Quote
Integy Weight Distribution System porschejim911 R/C Items: For Sale/Trade 0 04-12-2008 06:42 PM
Integy Digital Weight Distribution Gauge HenBeav R/C Items: For Sale/Trade 4 08-20-2007 01:04 PM
Integy Digital Weight Distribution Gauge Bob Nilsen R/C Items: For Sale/Trade 5 12-19-2005 10:43 AM
Integy weight distribution system fire929 R/C Items: For Sale/Trade 9 03-26-2005 01:50 PM
For Sale: Integy Weight Distribution Scale gporta77 R/C Items: For Sale/Trade 0 01-10-2005 09:20 PM
SEO by vBSEO 3.5.0
