Tire Compound TQ ??
Tire Compound TQ ??
Quick question what would be the best Tire Compound for parking lot racing ??
That's true I'm new to racing , one more thing is there a set up board or set equipment that I can use for 1/10 scale as well as 1/8 scale on road and off road ??? So I don't have to buy stuff for both scales ??
you don't have to buy different set up equipment for each scale
the droop guage and blocks can be used for 1/8 and 1/10 just makes sure you get the 1/8th once
you can use the rpm chamber guage for both classes i believe
Ride height guage is the same too
you dont really need the whole set up system it just makes your life easier and if you get it you have get 3 different systems one for 1/8 on road one for off road one for 1/10 th scale
just get the big 1/8th set up board so any scale can fit on it
Ok sweet thanks for info. One more thing what pinion gear is used with 19t motor my spur gear is 128 ???
what car and what 19t and size of track
it's a 1/10 Jrx-s pro s far is track not sure dimansions but it's kinda indoor size .
i would suggest a 35 pinion check your pm
in Parking have dust we use Trinity Buggy Grip 2
in asphalt use Paragon FX 2 , no other choice
in Carpet use Paragon Ground Effect .
