Tekin RS ESC sensored
Jcarr, what motor?
And for those asking for my setup: I will try and fill out a setup sheet today or tomorrow and post it up.
OOOOOOPPPPPSSSS sorry bout that It's a Ballistic factory set timing at the N mark.
Ok, I had my first chance to run the new software this past weekend. What i am experiencing is what i can best describe as turbo lag. I hit the power comming out of a corner and teh car is really slugglish then after about 3ft it starts to really take off.
Here are my settings:
Car: Tam 416
FDR: 6.12
Track: 120x72 fast but with a few tight corners
Drag: off
brake: 100
nw: 56
motor: bl-fw
tp: 3
cut off: 6.430
push: off
timing: 30
turbo: 10
delay: .2
start: 4989
end: 14997
ramp: 2
I tried changing the timing to 40 and boost to 15, it helped some but still had the lag. Temps after 6 minutes 140 and 135 after the change. What do the gurus think, am I getting too much timing too soon? Should I set the delay back a little? Thanks for any and all advice.
Car: Tam 416
FDR: 6.12
Drag: off
brake: 100
nw: 56
motor: bl-fw
tp: 3
cut off: 6.430
push: off
timing: 30
turbo: 10
delay: .2
start: 4989
end: 14997
ramp: 2
Man I am not with it this morning. 17.5.
BUKIL: I have been running that nw forever, I have set it down before and never noticed a difference. I remember reading a while back that Randy recommended it be set a bit higher to avoid some problems and that was the factory setting so I just left it there. I haven't tried dropping it with the new motor though and could always give it shot though. Thanks.
I thought about trying that thanks. That kinda leads me to another question though. My internal ratio come out to 2.0555555555 ect ect. When trying to figure out fdr should I use 2.06 or 2.05? I was usuing 2.05, but figure 2.06 whould be more correct. The fdr I put in my set up is from using 2.06. Sorry for the newbish question just ttoo much trying to figure all this out at once.
Yeah i know it's small, but just wanted to be as accurate as i can. It a Tamiya 416 18t center pulley 37t diff = 2.055555555........ Sorry for the OT.
Here are my settings,
Car: Tam 416
FDR: 6.12
Drag: off
brake: 100
nw: 56
motor: bl-fw
tp: 3
cut off: 6.430
push: off
timing: 30
turbo: 10
delay: .2
start: 4989
end: 14997
ramp: 2
Car: Tam 416
FDR: 6.12
Drag: off
brake: 100
nw: 56
motor: bl-fw
tp: 3
cut off: 6.430
push: off
timing: 30
turbo: 10
delay: .2
start: 4989
end: 14997
ramp: 2
FDR: closer to 6.0
Boost: 45
Start RPM: 3000-4000
End RPM: 10000-11000
Turbo: 10
Delay: .4
I think you have your RPM range set too high, and a tad too far apart. 3k-10k will be much better. Now, this is a more agressive setup, make sure you check your temps after 2 min, 3min, 4min, 5min, 6min, etc. You want to keep it from going over 150 if you can.
-brandon
First, the problem is NOT your neutral width... that is totally unrelated. But still, you could drop your NW down to 30. Here are the settings I would change to assuming you are running 0 degrees on the motor can:
FDR: closer to 6.0
Boost: 45
Turbo: 10
Delay: .4
-brandon
FDR: closer to 6.0
Boost: 45
Turbo: 10
Delay: .4
-brandon
Car: Tam 416
FDR: 6.12
Drag: off
brake: 100
nw: 56
motor: bl-fw
tp: 3
cut off: 6.430
push: off
timing: 30
turbo: 10
delay: .2
start: 4989
end: 14997
ramp: 2
Car: Tam 416
FDR: 6.12
Drag: off
brake: 100
nw: 56
motor: bl-fw
tp: 3
cut off: 6.430
push: off
timing: 30
turbo: 10
delay: .2
start: 4989
end: 14997
ramp: 2
1. Turn the turbo up and delay to 0
2. lower your end rpm as already suggested and turn your delay up.
You could also turn your boost up. It is a bit conservative.
I run my car both ways I have suggested. It depends on the track. I like option 1 on short technical tracks and option 2 on big flowing tracks.
FDR: closer to 6.0
Boost: 45
Turbo: 10
Delay: .4
-brandon
FDR: closer to 6.0
Boost: 45
Turbo: 10
Delay: .4
-brandon
JCarr, where are you for temps after your run? Assuming your down around 90-100F (which is what Im guessing your at with your settings)... For 17.5 your range should be about 100* your boost+turbo... so your window is very big...if you reduce it (by lowering the upper limit) the punch will come in faster...
assuming the temps are low, you problably wanna keep bumping up the boost and watching temps... with 0-10 timing on the motor you should be able to get to 50 boost and 10 timing no problem (range of 6000... say from 70XX-13000...
The boost/turbo is exponential, so 10 boost does very little, 20 boost does more then twice as much kind of thing.... With the 0 delay setup you have more control over when the turbo boost gets layered in, so you might want to play with that also (as other suggested).
-b
NW of 50+ is crazy, should be less then 15 max, i run mine at 5 no problems. running higher values is going to make the throttle an on/off switch, instead of giving you something linear.
-b
-b
My temps were 140F and then when I upped the timing and shortened the rpm range it came down to 135F. I wanted to be on the conservative side of things so I didn't hurt the brand new motor. At these settings the top end is great, actually it's pulling long past where I need to let off to make the turn at the end of the straight. So I could do with a little less top end, but there is just this lag at the bottom that is killing me off any corner where I have to lift completely. It's like the car idles to a point and then takes off. It's not a violent take off or anything, but the just pulls real hard all of the sudden. Like it should right after I hit the throttle from the corner.
