Tekin RS ESC sensored
Trader Rating: 25 (100%+)
RS
Well-- I finally did the SMART thing and went to the Tekin web pages---and DOWN Loaded the "experienced guys" settings for various motors and conditions. I've got 1/12 scale cars and 1/10 sedans---13.5 motors--17.5 motors--and carpet tracks -- asphalt tracks!! Once I checked out the reccomendations-- I learned a LOT about what I was doing wrong.
Gee---use some of these--IE the 1/12 carpet 13.5 setup--and WOW--nice speed and power through the infield and ballistic down the straight!!
LIFE IS GOOD!!!
Thanks Tekin--- you guys have got it right!!
Sorry these guys are having trouble with the Pro-- I'm happy with my RS systems.
T
LIFE IS GOOD!!!
T
if you blow the motor, it shorts out the windings, and will also think its the wrong motor. thats what has happened to me in the past with the 1,2 & 6,7 flashing.
I just wanted to know if they send in care what it cost me?
I already spent 240 Eruo in Italy for the Tekin RS pro.
Dave
timing
Can someone explain the specifics of adjusting timing in sensored only and dual mode? I read somewhere that in sensored only mode, timing can only be adjusted via the endbell, not through the timing boost setting in hotwire. In sensored only mode, does adjustments made to turbo boost and turbo ramp affect timing? Finally for good infield response in sensored mode, can I reduce motor timing via the endbell to gain acceleration while raising turbo timing/boost to increase top speed?
Thanks in advance
Thanks in advance
Thanks in advance
Thanks in advance
Randy pike please
I would like to know more on ep and gp 1/10 scale drag racing rules and regulations cos i am planning to organise one in my country. May i know the full details on http://www.teamtekin.com/2009TPWCNats.html Mackenzie Taylor car scale, motor,etc. Thanks in advance.
a lot have been experiencing this lately. too bad.
Tekin Support?
It sure seems that there are an awful lot of issues with Tekins ESC's lately.
I knew of problems with the RX8 also, yet no public comments are posted as of any running changes or updates made to this ESC or to the RS series of ESC's.
I fully support Tekin as they work through some of the problems with reliability they are experiencing. However, it would be nice to publicly state any revisions they are making, and how this will affect any warranties. If I buy an older (current model now) ESC that is prone to having issues, I would think it should be covered under warranty if any updates have been done. The issue may be mute if a new model/revision is released??
I found out today that I have a 'bad' 200 version software for the Hotwire. It says 'Beta' on it and allows the motor timing to be advanced to 50 degrees. Another fellow racer just happen to glance over and notice it. It said it will over heat the motor and to get rid of that version.
I need 200 version due to VTA - Ugh
I use the Tekins in SCT, VTA, 4wd SCT, 1/8 scale (RX8), 1/10 stadium trucks, 1/10 4wd etc etc... (damn I have too much stuff - lol)
So I support Tekin through their 'learning curve'. How will Tekin be supporting those people in return?
Can anyone help me get a good version of the 200 software please
Peace
Peace
Hi, who do I contact to send in my tekin esc ? It blew up yesterday
thanks
thanks
Hi Guys
Can someone help with a problem I had with my NEW RS Tekin last night. I ran it for the first time. I ran it in practice and it stopped working.
I hooked it up on the laptop, and the setting had change from sensored to dual mode, so I re-set it back to sensored, but when turning the esc back on, lights 1, 2, 6, n 7, were flashing? I re-set the handset to the esc, but still no joy. I've also tried a factory re-set but still no joy. Can someone please enlighten me.
Cheers Malc
Cheers Malc
Cheers Malc
When I had that, one of the phases was burned on the ESC.
The esc had run fine for 2 days, suddenly the car stopped on the straight, it showed max temp lights (was only 2-3 leds in noral operation).
I disconnected the pack, let it cool down, reconnected and leds 1-2 & 6-7 were lit up. Nothing I did could change anything.
Motor ran fine on another speedo.
Sent it to Tekin repair and it was returned within 3 weeks.
