Tekin RS ESC sensored
IMO it's the Duo1.
I have a question for the masses.
I am looking for a WGT 10.5 setup for a 36x100 non technical carpet track. Nice and high speed track. I have a decent 13.5 setup that has really long legs, but some folks wanna run 10.5 cause they "gotta go fast". I am also asking about gearing. I have a Novak SS 10.5 but would like to use my Duo2 and need settings for that one.
I was looking through the forums for Donny's snowbirds setup, but could not find anything. Lots of pages to sift through.
Thanks,
Tim
Thanks,
Tim
Donny Lia Post #11790
Here is what I used to TQ 10.5 1/12th at the Birds.
Push control - 20
Neutral Width- 10
Brake strength- 100
Timing Boost- 43
Turbo Boost- 7
Delay - .1
Start/End - 4000-8500
Ramp- 3.0
Trinity duo-1, Mid timing
32/78, 1.68" tire
55 mm rollout
Push control - 20
Neutral Width- 10
Brake strength- 100
Timing Boost- 43
Turbo Boost- 7
Delay - .1
Ramp- 3.0
32/78, 1.68" tire
55 mm rollout
Nice sharing Capt!
Do you race WGT too?
Tim
8.5T 4000Kv use what setting in RS Pro ?
Trader Rating: 51 (100%+)
maybe we dont have enough computer programmers playing with RC cars, but has anyone thought of making an ESC settings wizard. type in your car type, FDR, tire size motor kv, battery , track size and style and race length and it would give you some starting ESC settings. just an idea. something worth doing if its decided to make the timing boost feature even more complicated.
21.5 Settings
I am running a Redline 21.5 and an RS in a 416, i am looking for guidance in setting up controller settings. Any suggestions regarding set up parity compared to 17.5 as 21.5 is a new class we are running, but we have a few people who are successfully running 17.5 redlines with RS controllers.
We are running on ashphalt outdoors with medium grip.
Bob
Bob
hi guys,
Im just after a good setup for 17.5 trinity nemisis in a TC running sorex rubbers 1425grams. On a Medium/Technical outdoor ashpalt track
As i smoked my redline 17.5 last race meet (my own fault , with wrong settings/too much timing), First motor i have ever blown in 4.5 years of racing tho. So im not crying too much .
Yes, push control is 50. When its off the brakes are almost like drag brake force even when you do not turn on initial brake force. So 50 should be ok as it is still rolling even when you release the throttle.
You should check the spec of your motor. My orion vortex pro stock 11.5t has 25160rpm on 7.4v. On Kv its 3400. You should play with your fdr since your rpm is unusual and check the temps regularly on esc and also motor temp. Give me a feedback once you try.
Glad it worked for you. What was your temp? and pm me your setting. im trying something new and it might be faster than that one i gave you. Thanks
Regards,
Felix
any video tekin rs pro turbo in action?
