Tekin RS ESC sensored
any idea what kind of current to expect on a 2.5 on 2s lipo in a 1/12 pan car? i have a maxamps 2s 20c 3100 lipo that supposedly can handle about 100 amps surge/burst and was wondering if i went small enough in pinion if it would handle it.
Question for Randy etc at Tekin.
With regard to the weak brakes problem that a lot of people have expewrienced, including me;
It has bveen suggested by another person who has suffered to try setting the motor to forward & reverse, the reducing the brake/reverse endpoint of the transmitter down to a level that enables the speed control to try and engage reverse but so weakly that it actualls appears as strong brakes.
I.e, when my reverse side is set to 35%, if I hold the car off the ground and pull back on the stick I get the high pitch 'frequency' type of sound but no reverse movement.
My main question is, If I race with it like this using weak reverse as my brakes, will this cause any damage or overheating etc.
Skiddins
Skiddins
Skiddins
Skiddins
i have just come home from my local track , and i am quickest down the straight , the others were using the new GM120 and the Mamba max pro
i am not the best driver in the world but this speedo has some power in it , i was running an SPX last year with the GM 13.5 and i had gearing of around 4.5 to 4.7
now with the Tekin motor and speedo i am at 6.8 , and think i could go to 7.0 to gain some more punch out of the infield ,
GREAT SPEEDO THANKS TEKIN
just hope my driving is as good LOL
Phil what was your setup?
Hey i was just wondering what is a good starting point for a 4.5 in a TC5 would be? Its a redline motor and RS Pro
Thanks Jason
Thanks Jason
I would not reccomend using the reverse as brakes. I haven't tested it but I would expect higher motor temps and more battery usage.
We're working on new software right now and I'm confident you will like the results.
For the 4.5T setup: How big is the track? What's the application?
what kind of set up are most seeing at the track if they are willing to share,i am seeing 1/12 setups being used in tc
If for some strange reason 2 cell is legal for you I would recommend not running a motor lowe than about a 5.5 if you want to have any chance to make time and keep things from burning up.
It will be asphault with above average grip temps for track vary from about 60-110 strait away about 110' long
Thank Jason
Thank Jason
