Tekin RS ESC sensored
#1351
#1352
Market: what car?
#1353
#1354
#1356
#1357
I apologize if this has been brought up in a previous thread. I have a RS with looks to be cogging problems. THIS IS NOT A RIP ON TEKIN. I like there products, I'm just trying to find out if there is something I can do before sending it in. I'm running a 13.5 brushless motor. It looks as though the ESC is not picking up the sensors. When I turn the motor over manually I'm getting no lights, as well when the car is at full the lights light up full, then within a few seconds they start to pulse, then return to a solid full again. Any help would be greatly appreciated.
#1358
There are 3 possibilities, it's either your sensor cable, the motor or the speedo.
Easiest thing to do is to check your sensor cable. make sure you have it the correct way round, if you do then try another cable and see if it makes a difference. You seem to have picked up on the LED sequence to check on the sensors so i won't say again how to check them.
If the changing the sensor cable doesn't make a difference, then it could be your motor. LRP motors have been known for having issues on the plug for the sensor cable, so it could be that, or it could be your sensor board that's fried. Try another motor, you don't even need to unsolder yours, just plug the sensor cable on the new one and turn the shaft manually to check on the LEDs.
If all this doesn't make a difference, then something's wrong with your speedo and you need to send it back.
#1359
Tryed another motor,and same result. As it stands I'm running a HB cyclone 12 w/Novak 13.5, with a 62.5 roll-out. Going to try a older version of the Tekin interface see if that helps.....any suggestions are welcome.
#1360
I know, might sound stupid.
But how can I set Hybrid mode? the hotwire let me flag only sensored or sensorless
#1362
Nope just tryed the older version, and nothing, switched back and nothing, still not picking up the sensors, tryed adjusting the settings on the interface and nothing. Any new tricks out there?
#1363
Got to run the RS pro again today man awesome ran 17.5 lipo oval. qual 2nd took the a main win.
ran it like this
profile 5 sensored mode minimum netral width max breaks no drag break.
ran it like this
#1364
Just returned for the Sprint car Fall Nationals @ Bumps and Jumps speedway in PA. 220 miles one way. Friday was Practice and Racing Saturday with 3 heats ans mains. I ran the RS with the Redline 13.5. I qualified 3rd and finished 1st in 13.5 Sprint car. My car got faster in each race.
http://www.dirtoval.com/forums/showthread.php?t=33962
#1365
RS with throttle spike
Hi,
I just want to check on the problem that I'm having with my RS ESC. The ESC has been working well for the past few months.
Unfortunately for me, in the last 2 weeks, my ESC went "crazy" and it went full throttle all in a sudden. This has caused many big crashes and I have retired the car equipped with the ESC.
What actually went wrong? is it the ESC or the power cap?
