Tekin RS ESC sensored
Could someone help me please!
I need a reliable setup for a short carpet track (10sec laps) with 13.5t. Could someone please link me one or post it here. I need lightning quick acceleration and decent straight speed, i seem to have dramatically one or the other cant find a mid point.
A friend did the hotwiring today, no matter what he did to the thing it was poor on the straights was reaching top speed about 1/4th of the way down the straight, out of corners was fine. RPM was 15000, start 1000. I was about 7.7 fdr to start with and ended up at 5.85. The boost ended up at max.
Yet last week the thing was too quick down the straight, i couldnt control it. It got the point where i couldnt find pinnions small enough. Now its the opposite, Im so confused. Could someone who knows about these things please help me out please. :P
the straight is around 70 feet.
Trader Rating: 25 (100%+)
Tim
Does Tekin still offer a sale on its products to military personnel? How does that process work?
The base settings are going to be slow, even in sensor mode with full endbell timing.
Without a Hotwire you can't change the settings from the timing and you can't update the speedo.
OKAY --thanks--- I'm "old school"--these new fangled esc's have me behind the 8 ball!!! I'll find a hotwire and see what I have to do.
Tim
Tim
Is there any performance difference between the rs and the rs pro. Thanks for any help!!!
Exactly the same just the rs pro runs cooler when running lower mod motors (Ie the rs can only handle 5.5 and higher where the pro there is no limit on the motor.)
I am running a 200 mah life receiver pack in my WGT. When I run a Speedpassion ESC I will use about 50 mah per 6 min heat. With my Tekin I use about 150 mah in a 6 minute race. Is this normal, is this also why the Novak booster doesn't seem to like this speedo after 203 was released.
Used the tekin for the first time today... it was nuts, so much power i couldn't beleive how quick it was lol. Only problem i had was that the boost was cutting out about 2mins into a race, i spoke to another racer and he said to reduce the end point on my radio then recalibrate the remote to the speedy then increase the end point. It solved my problem which was great, something about the signal fluctuates between the remote and speed controller but only with KO Radios (im running a EX10), i think if i remember correctly their was talk about this not long ago on here? Other than that i got one good race in but motor come off a little hot (85 degrees C) , just need to fine tune the speedy now to get the temps down.
Good job Tekin!
Good job Tekin!
Good job Tekin!
Good job Tekin!
I'm going to be running the Ko helios with the duo2 very soon.
