Tekin RS ESC sensored
Yeah, I know it sounds crazy, but I see alot of people having this problem with the Novaks. I had the same squealing even with only 30 degrees of timing added. I first tried reducing the timing on the motor and it made it worse to the point under no-load conditions it would squeal on the car stand. Since that made it worse, I advanced the timing on the motor and the problem went away. I believe there is something that is not right with the novak ballistics. I noticed there appears to be very little help out there for the novaks and I do not think it is in Tekin's best interest to comment on one of their competitors motors in my opinion.
R/C Tech Elite Member
Location: Lost in the Dead Space between my Ears Somewhere around Wamego, KS (OZ Land)
Something is off either way. Yes if you continue to drive a motor that is cogging you can not only ruin the motor but ruin the speedo also. Cogging is bad and should not be driven through.
For 7.5 your setup will differ greatly from a 10.5 setup.
Each brand of motor is also different enough to make certain changes to compensate for them.
This is why we always reccomend starting with low settings and working your way up to the big settings. Going big right out of the gate can cause huge issues, as you've found.
There are tens of thousands of RS users right now not having issues. But for those of you that do have them, we're here to help you work them out.
I just got two speedos from superior hobbies in florida their website said they had 14 left in stock.
like this should be dailed
can 10
boost 45-50
turbo 5
delay .1-.2
ramp 2
end of 10000ish and start of 3800-4500
Then gear accordingly
finding most of my setting will run same gearing as 199/200 did
I got lost.
I have just downloaded Hotwire 4.0 and inside it shows there should be a 200 esc firmware available beside my current version 198.
I have an RX8 , which is the latest ESC firmware version ?? On the Tekin site I see 198 but the software highlights there is a 200.....
So to summarize
Hotwire 4.0
Vegas 2.0
Latest ESC firmware ??? 198 ? 200 ? 203 ?
Then, into the pilots settings they refer to 203....OMG....could you please help me ?
Thanks in advance
So to summarize
Hotwire 4.0
Vegas 2.0
Thanks in advance
I got lost.
So to summarize
Hotwire 4.0
Vegas 2.0
Thanks in advance
So to summarize
Hotwire 4.0
Vegas 2.0
Thanks in advance
If that is case you should be running can timing instead of early start of boost. you will need to delay your turbo a bit longer too. smaller tracks settings
can 10
boost 45-50
turbo 5
delay .1-.2
ramp 2
can 10
boost 45-50
turbo 5
delay .1-.2
ramp 2
Had a good day of testing,there were three of running all rs all had different settings each had a noticeable difference style in the infield but the same for the straights.only thing is i have no 3xxx start range there is a 2xxx and 4xxx, any one else see this,all where calculated in the 10k-14k range
OK guys, I took a step back, and soidered the esc back up to my 10.5Ballistic, added timing to the end bell and the car runs, but still clogs, the added timing has helped but not fixed the problem, I do believe even thou it smoked a motor, I dont think the esc has changed any, so "IF" the esc is not bad, and that Orion motor was a bad motor, what do you do to make the esc work?????
I just ordered a 13.5 Redline motor, I will get in the car and see how it acts I guess. Everyone told the ballistic motors would work with the RS Pro, but I cant get it to work. Tried of getting mad at a toy car.
