Tekin RS ESC sensored
uninstall everything and go one more time and after in stall take a screen shot if you can,or try calling tekin and talk to chris
yea looks thyat way, hey for a small small track 50 ft straight.. does 76 rollout seem to high, 13.5 1c? 1/12
don't know yet haven't got a 1/12 yet I'm waiting on a new one
Tekin RS Pro / 6.5BL / Durango DEX410
what profile should I use for the above?
have v203 software
racing at this indoor venue
have v203 software
+ YouTube Video | |
With that said, some guys gear in the 80-85mm roll-outs with 17.5 but my motor just seems to like light gearing. Therefore you really probably just going to have to experiment to find the gear your motor is going to like best.
still cannot get 203 on my labtop, i have a new dell Core 2 duo, windows vista, labtop...when hotwire come on says something like the esc settings exceed the hotwire capability's or such. is it just a matter of it simply wont work on certain pc's? i deleted hidden file etc...
You must remove the hidden file, go to control panel and uninstall the old software, restart, install the new.
Here's a help vid:
http://www.youtube.com/watch?v=tTp3tUL9u8Y
i did that a while ago, and re-checked several times to make sure its still not there, going to track in a hour ,to turn it out, is there anything else we can do? could i call u , maybe we can go thru it?
Hot wire problem?
Do I have a bad one?
I just tried to hook up a new hot wire I bought and I have no communication with the speed control.
The USB "dings" when I plug it in, The led's on the hotwire itself light up ( green/red/red/red) The speedo lights up but it will not open the program automatically. When I click on the icon on the desk top, the program opens for a few seconds and comes up with an error, Hotwire not detected, please check USD /speed connection and restart... which I have done and continue to get the same message?
Any idea's?
Any idea's?
Hot wire problem?
Any idea's?
Any idea's?
Hot wire problem?
Any idea's?
Any idea's?
well, i am running a duo2, static timing right about the middle of the markings, about 45 boost and a rollout around 64mm. this track was about 65 footl ong. car rips!
Hot wire problem?
Any idea's?
Any idea's?
You cannot use the Hotwire on a USB hub, if it does work you run the risk of ruining an RS.
Try another USB port, sometimes they don't work even though you get the "dink" noise.
Non-warranty replacement
Is the "non-warranty" replacement RS I just received a new or reman. unit?
What happens to all the old speedos?
Thanks guys for the quick reply.
Not using a hub directly into computer.
With that said, I tried on both a lap top and and home computer, same error happens no matter what USB port it is in... ( I tried 7 total)
Any other idea's?
Any other idea's?
