Tekin RS ESC sensored
i will admit to..i was a little scarred to install it.being that i never tampered with none of the other versions.this is my 1st tekin esc.i was using an lrp sphere tc esc.i installed this version as soon as i got my tekin and went out after having some help with what settings to try.it felt good and smooth untill the turbo kicks in.then it just throws my timing off.so i have been trying different settings to get the turbo to come on alot quicker.i will find out tomorrow how it works.if i do not like i will try turning the boost off and advance the timing to try and get that raw/smooth feeling like as i did with the lrp.im not sure track size.but its not real big there and its not as small as some of the places i went to.
alot of this softwear confuses the crap out of me.so im trying to learn this all i can.
2s, what would you recommend me checking? I was thinking that I should redo all of my solder joints on the esc and battery to make sure none were cold.
I've seen that happen with 6cell NiCd when the pack was getting bad so I'd suggest borrowing a different battery and trying that. If the problem still persists then you likely have a BEC problem with your ESC not giving enough power to the RX.
track size is 70x75
New RS Pro
Hey guys
I'm looking for a starting point for the RS pro on a 80x36 carpet track. Usually will have full straight w/sweeper....technical infield.
This is my first time with tekin so any help will be appreciated.
Doug
Doug
what batteries are you using 1S lipo or 4 cell?
rollout for 13.5 1c 2,500-10,500 sound alright? small track
Hi All been reading through this epic thread trying to get up to speed on settings etc after running my rs 203 for the first time last week and think i've got it figured out (testing will confirm that) nice work Tekin!.
It seems to me that one of if not the most important setting in hotwire is the end rpm which you ideally try to match to the max rpms acheived by the motor you are using, FDR and the track layout etc. Now correct me if i'm wrong but the rs detects the rpms the motor is doing at any given moment right?
So something that would ease setup would be if i where to zero all boost settings etc in hotwire and 0 the timng on the can pick an FDR which suits the twisty bits then run a couple of laps the rs would know what the max rpms acheived where and could list it as say a recommended setting the next time i opened hotwire. Not sure if this is possible as the rs would need to be able to write the data and have somewhere to store it. Just a thought all comments welcome
Mistake? Hope not!
Hope I haven't made a huge mistake ordering the Tekin RS & HotWire I haven't even received it yet (BO) and it has already been a huge PITA! Thought I would get a head start and go ahead and download the HotWire software ahead of time. Easier said than done, I had to register 3 times before Tekin sent the email with the zip file and then install and uninstall the program 3 times before it installed properly and as I still don't have the Hotwire I'm not sure it did install correctly. Hope it's worth all the trouble. I wish it was more like my Castle Link a few clicks and it was up and running. Oh well we shall see
I don't know how people are getting these mishaps and maladies on their speedo. I never had trouble with mine nor any hassles downloading the new firmware.
Maybe, I'm just lucky?
Mine also installed quick and easy. No problems at all. The Hotwire has worked flawlessly in applying settings to the speedo.
I purchased my RS just after they became available (October 2008?). I've downloaded four different versions of updates and never had a problem in the download or programming with the Hotwire.
I too don't understand why people are having problems.
