Tekin RS ESC sensored
#9436
Thanx for the update
Car Turned to Crazy-Scary LOL
Are these ok;
I need to drop down to 4T smaller Pinion than normal
is 3500 rpm start has less torque than 4000 rpm?
is 45 timing boost + 5 Turbo +0@motor safe to start? with 6.86 overall ratio @13.5T ?
Thanx in advance
Are these ok;
Thanx in advance
#9437
i installed 203 and was able to program speedo fine. Then i went to click on hotwire again and it just pops up an error message. I uninstalled hotwire and re installed and still an error message?
#9438
http://www.teamtekin.com/hotwire.html
#9439
did you regester and get a email from tekin.it says here that its 4.0
#9441
So help me fully understand this....
With the 203, there are now 3 stages of timing?
Boost which comes on with in a few feet
Turbo which comes on after a set delay and has 3 different "profiles" of how timing comes in.
(I am pretty sure I understand those two timing advances because they are the same as before except you can add more boost now and turbo has profiles.)
I don't 100% understand what is going on with the RPM settings. Is this a third timing advance that comes in at the set rpm and stops at the end rpm?
Start rpm is when boost kicks in at
End rpm is when you hit max boost
Turbo kicks in after the ending rpm and the delay that you set.
This new layout is just what I was looking for in a speedo. I know of someone doing some prototyping of esc software and hardware that has this mid throttle rip that is incredible. My Tekin without 203 did not have anything for it. Now I do.
#9443
thanks
hai randy just got a e mail from tekin n download already not yet test maybe on sunday btw thanks alot hopefully my ride like awesome
it not to late to wish happy new year to randy n team tekin n for all rc member out there
happy new year guys
happy new year guys
#9446
oops, Kenny Lamberts earlier v200 setup had a 3.0" rollout, "assuming" a 6-8 tooth knockdown on a "typical" TC pinion (35?) then 35-7 is a 20% reduction. so the new rollout is around 2.4"? this seems really low but certainly a safe starting point.
but since Randy Pike's 13.5 TC setup shows 7.04 FDR, maybe 2.4" is the new rollout!! (arrgh, anybody want to buy some barely used 45-55 tooth pinions!!)
i am sure some knowledgeable person will fill in the info.
#9448
Yes, the entire Tekin crew is here together celebrating! Happy Holidays everyone!
