Tekin RS ESC sensored >
Old 12-14-2009, 05:35 PM
  #8641
Originally Posted by Chris Furman
rough ETA?
Snowbirds?
Cammer is offline
Old 12-14-2009, 06:39 PM
  #8642
Uga
Uga's Avatar
Hi,
a friend of mine has a problem with his new RS: sometimes after standing still on the starting line for 30+ sec the motor won't run and he'll miss the start. It's strange because he ran a few warmup laps before that and it was OK, but after taking starting position you have to unload the rear tires to make the motor run, after that the whole run is OK.
Using 2S Lipo in World GT with newest software updated, Tekin Redline 17.5T motor, temp is fine, usually under 60°C.
Has anybody seen something simillar?
Uga is offline
Old 12-14-2009, 06:59 PM
  #8643
Trader Rating: 118 (100%+)
Originally Posted by Uga
Hi,
Yup,
1. motor overheated at one point, try different motor
2. sensor cable is bad, try a different sensor cable
3. reflash the Tekin (highly doubt this is the problem)
Chris Furman is offline
Old 12-14-2009, 07:14 PM
  #8644
Trader Rating: 19 (100%+)
Hi,
I had the same thing happen to me this past weekend. After going thru everything found to be the sensor wire. I unplugged it and plugged it in a few times on the speedo and problem solved. All my stuff, motor speedo combo was new. First time out with it in the WGT this past weekend.. After that all was good. Hopefully thats your problem too.. Hope this helps..
DHMOTORSPORTS is offline
Old 12-14-2009, 08:31 PM
  #8645
Casey Belarde's Avatar
Originally Posted by mkdut
You need the booster or receiver pack to get everything to function properly.
Originally Posted by Geezatec
I've emailed Ty @ Tekins a months ago. Going with 1S lipos. You do have to install a booster, or a battery pack, one or the other, but not both. Hotwire do ck on 1S lipo. He say www.tqcells.com has a good one.
Good Luck!
BINGO!!!!!!!!!!!!!!!!!!!!!!!!
stop by Doc's house tonight picked up a TQ booster badda bing like magic everthing is working now
thank you for all your help!!!
Casey Belarde is offline
Old 12-15-2009, 12:07 AM
  #8646
mattyau's Avatar
could anyone recommend me what size pinion and spur for a tekin 21.5 motor running a tekin rs with a trans ratio of 1.7 (xray 009) to get a idea on a correct starting fdr ive got a 33 pinion and 71 spur in there at the moment giving me a fdr of 3.66 but it got fairly hot after only a few laps and its all ive been able to get down as time has been an issue for me. would it be over geared or under geared, im not sure if its my gearing or my esc settings at full throttle you can hear the turbo quiet loud sorta sounds like its rev'ing to hard when at full throttle.
sorry for the random questions if they have been answered before also i cant post my esc settings untill i get a chance to borrow a mates hotwire
mattyau is offline
Old 12-15-2009, 12:19 AM
  #8647
I've been racing with a final drive of 4.6 in my RCGT and have been faster than most on the straights. NiMH 3600, Tekin RS, Tekin Redline 21.5, 10 deg on the can, 15 boost, 10 turbo, .7 delay. I experimented in the parking garage with less timing (especially down low) and a 4.2 final drive, but results were inconclusive.
final = internal * spur / pinion
pinion = internal * spur / final
spur = final * pinion / internal
A 26T pinion would give you 4.6. An 89 spur would with the same pinion would also give you 4.6.
-Mike
grippgoat is offline
Old 12-15-2009, 12:22 AM
  #8648
mattyau's Avatar
-Mike
cheers mike, i think i got 26t around. ill give it ago next chance i get
mattyau is offline
Old 12-15-2009, 01:41 AM
  #8649
tc3team's Avatar
Originally Posted by bkspeedo
No, it's smart adaptive control. I'm sure as the motor load lightens it increases timing. This also helps keep the motor operating at its highest efficiency thus using less battery power.
Hopefully this is what Tekin is working on and that the current Micro in the Rs can handle the computational needs.
I'm more than sure it won't take much to see what's components are inside the ESC and what it does for Tekin to come up with an answer...
If you understand an engineers mind, it is all just a mind game to "crack the code" and, naturally...
improve it
And then refine it!
tc3team is offline
Old 12-15-2009, 05:18 AM
  #8650
RC-ProSpeed's Avatar
How big is the track? does it has a long sweeper, or is a U turn after the straightaway?
I believe you are way off your gearing... unless your track is really really big...
on a 90 feet straight with a long sweeper, you could try a FDR 5.4 and adjust from there according to temps...
RC-ProSpeed is offline
Old 12-15-2009, 06:48 AM
  #8651
trerc's Avatar
Trader Rating: 89 (100%+)
A good place to start is around 5.0 check your temps and adjust from there. Good luck.
trerc is offline
Old 12-15-2009, 08:02 AM
  #8652
mkdut's Avatar
No problem. I experienced something similar when converting over to 1S.
mkdut is offline
Old 12-15-2009, 03:41 PM
  #8653
stiltskin's Avatar
Trader Rating: 103 (100%+)
I'd like to see some 17.5 setups that are working out for you guys. I'm pretty happy with mine right now, but would like to see what's working for you guys. Post track size and tire type as well.
stiltskin is offline
Old 12-15-2009, 03:44 PM
  #8654
20 SMOKE's Avatar
I'm hoping to get some in the next few weeks
20 SMOKE is offline
Old 12-15-2009, 05:13 PM
  #8655
Clint161's Avatar
+1
I can't get mine figured out.
5.0 fdr, 8 motor, 20 boost, max turbo, .5 sec. tekin 17.5 motor. What I've found works best for me but lacking punch..... big time!
Clint161 is offline
