Tekin RS ESC sensored
#7756
tried everything suggested above no luck. the turbo did work before, actually when i plug the hotwire to the esc it says the turbo setting is on and is set where i want it but the turbo doesnt come on. this sucks because i was planning on going to the halloween classic hosted by the gate.
#7757
When you geared good and your turbo delay is set right, than you don't see it coming in. Than your car accelerates smooth.
When you hold your car in the air do you than see the turbo coming in?
#7758
@Mikkiy
hi Mate
seems like you've tried many setup combinations could you please tell me what will happens if I lower my timing boost from 25 to 15 or higher it from 15 to 25 ???
thanx in advance
hi Mate
thanx in advance
#7759
What do you want to now?
The only thing I can tell is, is that a lower Boost will give you more power and a lower top speed by the same gearing.
I love a lower Boost on my Tekin 10,5 but on my 10,5 LRP I use about 5 more Boost and on my Speedpassion 10,5T even 5 Boost more.
So for the right setup you need some things before you can say what a good setup is.
This depends on a dew things.
Track size. Straight length and how the infield is.
Motor how many turns and also from witch company.
Each motor has his own setup.
I love on smaller outdoor tracks (big track for the US) to use more Boost and a lighter gearing.
On the larger tracks I'm on 15 Boost with my Tekin 10,5T.
Still I use a lighter gearing than all the other drivers.
On small indoor tracks I use a lower Boost and max Turbo but tomorrow I try a very light gearing with a lot of Boost.
Never tried it on a small track.
#7760
Do this... pick your car up in your hands, and give it full throttle for a few seconds. You should see the turbo REALLY ramp up after a second or two. If you can't get the turbo timing to work up in the air, you have an issue. If it comes on in your hands, but doesn't APPEAR to come on when the car is on the track, you aren't geared or timed properly.
#7761
Randy, do you have a speedo setup for an RS thats in a T4 with a Tekin 13.5? Also, if I leave the motor at zero timing, will that give me more rpm's? or should I change to the middle (10 degrees) on the motor and then set the speedo? Thanks for any help. This is for offroad.
#7762
Thanks Randy for all the help, you have been very helpful in trying to understand boost, turbo and timing, just orderd tekin rs 17.5, for 17.5 spec class, running ae sc10, regionals are in st. louis, mo in two weeks. Where do I start with sc10 and boost and timing, where will my gearing go up or down from a 0 timing 17.5 motor that I am running now. The track is 80' by 50', 75' straight and 180 degree turns also. This is dirt offroad sorry only place I found the rs being talked about.
Thank you
#7763
check the electric offroad section, there is a whole thread dedicated to different offroad setups for the rs.
http://www.rctech.net/forum/electric...ps-only-6.html
#7765
#7766
#7767
Slow Repair Time
Well Tekin received my RS for repair on the 14th of October and it still isn't back yet. (I didn't even get to run it in the car yet) Tekin must have a whole bunch of broken items to repair. I called them up Monday of this week and the repair dept. said I would be racing by this Saturday...........I`m still waiting
#7768
#7769
#7770
200v with Las Vegas
Randy,
Could you please email me the 200v with Las Vegas.
I have 189 right now and I have waited long enough, plus the carpet season has started and I have a new 12th scale to run.
Thanks and God Bless
