Tekin RS ESC sensored
#646
With the description of the Hybrid mode providing fixed timing at startup to me that is really detrimental to 10.5/13.5 performance, when the sensored mode is engaged.
I was of the impression that the sensored mode was only engaged when the motor was either not moving or at low speed. Does that mean that sensored is also engaged when the car is moving but off throttle?
#647
Should that be sensorless only? As i am pretty sure that a the RS is not gunna like running a 13.5 in sensorless mode only.
Why would it be detrimental at startup ? It's only just the same as all the other sensored motors. Besides at low speeds on a sensored speedo the timing doesn't shift much anyway.
In hybrid the sensored mode is only at startup or extremely low speeds that's correct, not off power.
#648
Quick (hopefully simple) question -- is there any advantage to getting an "RS motor/ESC combo) vs. buying the motor and ESC separately? Extra stuff in with the combo?
If not, I'll get the ESC now (have an opportunity to save some $) and the 13.5 motor when I can.
TIA
TIA
#650
I've run in both modes with a Novak 13.5 and to be honest, they ran pretty much the same for me on a long outdoor track.
The RS will go into sensored mode any time that the speed control can't accurately locate the rotor in sensorless mode. If it's on the sensor it has sensored timing. Off the sensor it has sensorless timing.
Motors like the Orion may be a little different because you can crank way more timing in on the motor. For motors like that sensored only mode may be the ticket for long tracks.
I've always started with zero timing in 12th because they turn so much less rpm.
#651
Li-Po with Mod motor use which mode ?
#652
TIA
TIA
#653
#654
After reading most of the posts below...sounds like I need to have a lot of setting to make the ESC works properly, soft brake..soft bottom end..heating..1 lap off the pace..firmware interfacing problem & etc...never read or hear so much problems with other ESC.. It really freak me out now
My RS PRO is delivering on the way to my doorstep.. Kindly of worry...
#655
The speed control is more adjustable than any other on the market and as such, you'll see people playing around with settings more. People with performance issues typically do not have the speed control/motor package timed or geared correctly.
#656
I couldn't be happier w/ my tekins!!
#657
#658
#659
BL newbie here. I'm contemplating the RS with a 13.5, the Redlines seem to be out of stock at Tower. Anyone can advice me on another combo, Vector X11 or Novak SS or ... ?
#660
One of the potential drawbacks of a highly configurable ESC is that you can get lost in the details. When you use something like a GTB, you basically get what you get, and learn to live with it. With the Tekin, as soon as you realize there's so much room to wiggle, you're going to want to twist every knob in hopes of squeezing out more performance, or better feel.
I think Tekin's only mistake at this point is that there isn't an easy default profile to make the ESC feel more like a Novak, or LRP. I see they're working on a way of sharing profiles online. It would be cool if they created some that mimic the other popular ESC's on the market, that way you could start at a known point, and then adjust to your liking from there.
