Tekin RS ESC sensored
#6001
Company Representative
hey guys
freind of mine who is getting a RS pro /hot wire, need set up help for first time.
He will be running a Lipo, speed Passion 13.5 on Cyclone TC, Rubber at Jackson raceway High grip/140ft main stratch.
also waht will be ball park FDR?
Thanks in advance
PS: also anyone selling RS? with or with out the hotwire? if you have em please PM me a price TY
Thanks in advance
#6005
#6008
Is anyone receiving 200 via yahoo email? I'm getting it as a txt file and my yahoo will not let me download it because it says it contains a virus. Anyone else having this issue? It's suppose to be a fwd from Randy. I didn't have this problem before with Tekin software as a txt file.
#6009
#6010
I have someone sending it as a zip file. I should of just used my Gmail instead. Didn't think of that. Thanks.
#6011
just a quick Q. in regards to manual/boost timing, is there any advantage of splitting the timing between the motor and the speedy, or is it exactly the same to dial in the amount of timing you want completely from the speedy?
Example:
manual timing: 10
boost timing: 10
turbo boost: MAX
vs.
manual timing: 0
boost timing: 20
turbo boost : MAX
Thanks.
Example:
manual timing: 10
boost timing: 10
turbo boost: MAX
vs.
manual timing: 0
boost timing: 20
turbo boost : MAX
Thanks.
#6012
hey, can you guys help me w/ getting the firmware for v200 my email address is [email protected], thanks alot
#6013
#6014
Gmail will not accept .zip files at all, first I've heard of Yahoo shutting it down.
If you can download the .txt file you simply need to "rename" and change the file extension.
Remember Yahoo guys I have IM: TekinTeamMgr the file transfer tool works ace!
Timing boost comes on after a few feet/rpms of car travel so running 0 motor timing should get you a harder launch when comparing those two setups, the speed should be near identical assuming they're geared the same.
Tekin 40c pack? Yeah what's up with that!
#6015
I had the same problem....So I forward it to my work e-mail and was able to change the file extension from .txt to .zip ..resend back to my yahoo mail..will know tonite
