Tekin RS ESC sensored
#5882
Skiddins
#5883
#5885
#5886
If I remember correctly the previous releases(189, 194, 198) also had BETA in the file name. Not sure why because those were the public release versions.
#5887
#5892
in regards to the timing, you could try 10deg manual timing on motor 10deg timing boost on esc.
#5893
Set all your TH settings to 100% don't touch the TH EXP. Leave it to 0.
But the straight is quit long.
If the straight is smaller, try 10 boost.
Last race I used 0 on the motor and 25 boost.
The run with 20 boost was the same lap times but the 25 boost gave me a bit more top speed.
The 20 boost a bit more infield speed.
I used on a small track 7 boost with max Turbo.
geared it heavier.
This was with a Tekin motor 10,5 with 12 on the motor
With the Speedpassion motor I use 18 boost and just 5 Turbo.
I'm geared heavier than the Tekin motor.
The Speedpassion motor runs better with a heavier gearing on that track.
#5894
I will let Randy answer that though when he's here next
#5895
http://www.youtube.com/watch?v=Pb--yQonviA
here is the track and what layout we will be running
thanks for the input guys
