Tekin RS ESC sensored
#3226
Adam?,
I think you should have tried more gearing options with your RS. My car is by far faster with the RS then it was with a SpeedPassion GT1.1. Myself and Mike where both faster this last Sunday by gearing down. I'm not sure what Mike is geared at but I'm currently at a 5.37 and pulled my fastest lap times yet. Given some better driving skill and setup I'd be right there with everyone else.
Mtr Timming min hole on Duo 13.5, I believe is 0 deg.
Boost at Max. - may try dropping a few points.
Throttle profile 3
If you still have one of your RS's I'd give it a try again by gearing ridiculously low and moving up using 25 to 30 boost.
Throttle profile 3
#3227
Ha ha ha, we'll see. I raced all last weekend at Silver State. I started seeing some new RCGT class poeple are talking about. I might have to look into that just take some time out of the Reedy weekend!
#3228
Randy - could you email me the v194 - I have been told it will eliminate the clogging on the Mini Rage. Heading out to the Mini Great Lakes Challenge, and would love to have the updated software. thanks
#3229
All software requests must be sent to me here: [email protected]
#3231
#3233
I assume your emial is [email protected] not [email protected] as listed above.
Thanks for pointing it out
#3235
As do you!
#3237
Hi Guys racing on a mildly technical outdoor track what would the best timing and boost setting be? using a tekin 10.5 motor and the rs pro speedo? tried it on full boost and 0 timing and doesnt feel overally fast not as fast as soom in the slower corners....
thanks
thanks
#3238
Pro, try running 20 on the motor and 10 on the boost to start out. Gear down a bit and make sure motor temps are in the right range.
#3240
I should have asked this a couple of pages ago, but I didn't really think about it until just now for some reason...
When you say boost is "stronger" on the lower portion of the scale between 1 and 10, what exactly does that mean? Don't the numbers on the boost scale represent 1 to 30 degrees of timing advance? If not, what do they represent? If the numbers DO represent degrees of timing advance, how do you make 10 degrees in 1.94 stronger than 10 degrees in 1.89?
Not asking for any trade secrets I hope... but it is kinda confusing...
