Tekin RS ESC sensored
#2746
Suspended
If I am using an lrp motor would full boost be ok as the lrp motor you can't adjust the timing
#2748
My LRP Vector 13.5 has adjustable timing. Are you sure yours does not? If not you should not run full boost. Only add enough boost so that boost + motor timing is less than or equal to 30 degrees.
#2749
Suspended
thank you
#2750
Need help!! I'm trying to calibrate my KO Helios to my RS speedo. After setting the throttle throw, I get the 1,2,3 lights blinking indicating that my radio signal is lower than expecte. I tried making different adjustments with the same result. I even tried an M8 and still have the same problem. Anyone have a clue as to what would cause this? Thanks.
#2751
Suspended
thank you for your help
#2753
Suspended
No I am running the 189 software
#2755
Suspended
thank you
#2756
#2757
Try reversing your throttle channel. Ko's, Futaba's and a few others need it reversed to make our "window."
#2758
Iv'e been looking at trying another speedo. Ive tried the SP GT and TC Spec. Found the TC Spec to be much faster then the SP in 17.5.
Now after reading through this thread i'd like to try the RS Pro. I know i will need the hot wire unit how ever what version of software will i need since im in Australia?
Thanks....
Alex
Thanks....
Alex
#2759
Alex,
Most are using 189 software.
