Tekin RS ESC sensored
#2566
whats the kv's rating for a 9.5?
#2567
Anyone know why the combo's cost more then the individual components? For example the 21.5 combo with the RS Pro is $330 on tower but if you buy the Pro and 21.5 separately then its only $314. Am I missing something? Does the combo come with the hotwire or something like that?
#2568
The RS proved to be a secret wepon at the Febuary Freeze in 13.5 class!! Rumors in the pits were the Tekin with 189 wasn't fair!! A friend purchased a RS from the hobbyshop after trying everything in practice, but just didn't have the speed. I set him up with 189 at MAX BOOST!! He was in the A-main for late model class!!
I used the RS Pro with a Tekin sensorless 3t motor and had problems trying to keep the front tires on the ground!! I couldn't figure out why my car pushed!!
-Wayne
-Wayne
I can tell you that set-up works very well on dirt when the track is tacky, but this past weekend, for the 17.5 dirt oval A main, the track dried out some, and I was left to pedal a car with waay too much low end.
Did you guys experience any of that at the freeze, and if you did, what did you counter it with? I was thinking of using the current limiter, but didn't have time to work it out.
#2569
If you've got too much bottom end try the current limiter just like you're thinking. That's going to soften the bottom end and keep the top.
#2570
There was so much traction by Saturday that the 13.5's pulled the wheels! There were 60 heats of cars running on it. By the mains cars were traction rolling!!
#2571
Cant find a thread for the tekin 17.5, so
What FDR Or rollout are people running with this motor in TC Li-po 7.4v with Sorex rubber(63mm) out door track Large/medium. warm climate. Boost at max and motor at 0, car weight 1425g
thanks
thanks
#2572
#2573
#2575
With max boost and zero motor timing my roll out is 2.23 on a foam tire dirt oval EDM, and its wicked fast.
The other set-up I liked was 15 boost and 12 motor timing and roll out on the same car was 2.55....
I can't tell from your post what your running, but rubber tires will need an even lower rollout than the 2.23 I run. Our required weight is 3lbs 4oz....
#2576
It would certainly helped, had I known I had to peddel it, but its not exactly the same. I was using the linear profile 3. I like that the most, but my previous run 40 minuits earlier the traction was not an issue, but for my main, it dried out some. At speed, the car was a little loose, from a dead stop it was really difficult. With the current limiter, I should be able to set it so that under any throttle profile, I can hammer the throttle and get away cleanly if I have it set low enough for the available traction.
In dirt oval, your usually not letting off much, so the bottom end is not really needed to win, we like rpm. Its great to have torque off the line, but when you get tangled up, and have to take off from a dead stop, you don't want to have to think about it to get back up to speed cleanly. Your usually trying to get back out into traffic without getting run over. I will just set it at 80%, and hopefully not have to worry about it again.
I have also changed my tire goop compound and stratedgy to make this a non-issue in the future.
#2577
When you guys mention full boost and motor timing at 0 with the 189 software, what should the timing be set to on teh timing markings ? Should it be what the manual says is 0 or should I fully retard the timing on the motor ?
#2579
#2580
Anyone ever mess with the timing on the tekin 9.5? I am running offroad. Motor temp is 99deg. Gearing at 86/22 thinking of going up to a 24.. Track size is kind of small 65X43..
