Tekin RS ESC sensored
Before sending it back, try downgrading and then re-upgrading the firmware, especially if it worked before the upgrade. This has brought more than one RS back from the dead. At this point you have nothing to lose, and just might save a round trip back to Tekin.
I believe the new motors have timing ticks but for now what I did with my D3's is rotate the end bell each way as far as it will go and the made a mark on the can with a knife. That will give you a better idea of where your timing is relative to 0 (the one line on the back from the factory) and max (the line you made with the knife).
I have a question.
as i set the rpm range for sensord mode and set the advanced timing on 100.
will the advanced timing use the rpm settings from the sensord mode as you loose the sensor wire?
\it looks like i have moore power as \i pull out the sensor wire. if the car accelarates faster.
I don't feel that i loose extreem much power in the infield.
only driving away gives some problem but as I set the throttle on 15 it runs better away.
hey guys we are running 17.5 2wd short course with no timing or boost allowed. with 212 i have speedo in profile one for spec. can you reccommend a throttle and brake minimum. thanx. also on redline motor what should i start timing at. we can run timing in motor.. thanx i appreciate all the help.
I have a question.
The motor may cog a little from a dead stop, but after it is moving, you shouldn't have cogging.
Timing advance is only used a) in sensorless mode b) in dual mode, after switching to sensorless mode or c) in sensored only mode, whenever the sensor signal is lost for whatever reason (sensor board fails, wire gets damaged, etc).
Not that it happens but in case of.
Brake minimum is hard because I didn't notis it what it does.
my brakes are great now.
Motor timing.
as you nee a lot of power set it lower. As you need top speed set it around the standart timing or a bit lower. Motor gets wormer.
as you set the motor timing lower you can gear heavier.
find a balance in it.
one switch
cut black wire on switch/splice it into red rec. wire
R/C plus thead has more about how to do it.
learned it from them.
Need help, TURBO BOOST LOOSING AFTER 5 MINS. ESC rs pro FW:212
-motor: lrp x12 10.5t endbell timing: 0°(default) FDR: 7.18
-Boost: 40, start RPM: 8907, end RPM: 22032
-Turbo: 10, Turbo ramp: 2, Turbo delay: .3
-Voltage cut-off: 6.360
-Drive mode: sensored only
-Motor direction: normal
-Throttle profile: 1
-Current limiter: off
-neutral width: 20
No temperature problems ESC temp: 3leds, Motor temp: 60-63°C Max.
Switching off and switching on again the ESC, turbo boost back to normal.
thanks
-neutral width: 20
thanks
-neutral width: 20
thanks
-neutral width: 20
thanks
-neutral width: 20
thanks
-neutral width: 20
thanks
