Tekin RS ESC sensored
Looking for a setup for WGT with tekin rs and 13.5 motor using 1S
I tried it but I was looking for another setup that might work better.
what size track
13.5 1S WGT
Boost - 45 to 50
Turbo - 0
RPM End - 9500
RPM Strt - 2xxx
Roll out - 2.4-2.6 inches
Your liking on the rest
Motor Timing default or slightly above default.
17.5 1S 12scl
Boost - 50 to 55
Turbo - 0
RPM End - 7500
RPM Strt - 2xxx
Roll out - 2.9-3.1 inches
I've found that in 1S cars turbo does not have much effect, just makes the motor hot.
Boost - 45 to 50
Turbo - 0
RPM End - 9500
RPM Strt - 2xxx
17.5 1S 12scl
Boost - 50 to 55
Turbo - 0
RPM End - 7500
RPM Strt - 2xxx
can someone tell me what would make the on/off switch get hot. thanks
wires touching in side
Can I just let everyone know the 212 update fixes the brake problem on brushed motors from nothing on 208 to just as strong as brushless brakes on 212...
It is unreal as I am teaching someone new at my home town to learn about gearing and what not and 212 has just made brakes on a brushed motor work great...
Cheers tekin
Cheers tekin
Is it possible to put the reciever wires for the ESC on a Y harness to keep from having to plug/unplug? I realize that would mean always having the power off, like any other time. Would it work, or would the signal get attenuated/changed by having the reciever in parallel?
Looking for help. I am just getting into 1/12th scale racing just a question on do I need a receiver pack or booster which is better, and how do you hook them up. I tried to read back through as I am sure its been talked about but could not find it. Thanks
http://www.amainhobbies.com/product_...ack-66V-200mAh
either will work
i like the booster , it is one less thing to worrie about charging
