Tekin RS ESC sensored >
Old 10-18-2010, 01:35 PM
  #17521
Kevin K's Avatar
Trader Rating: 32 (100%+)
I run a race series and I have a question regarding the use of 212 over 208 in spec mode. Will there be a distinctive difference in the pattern that the lights flash when in neutral between the two? So when we are in Tech and looking for the flashing lights will we be able to tell that someone is on 212 with out having to hook them up to a PC to get a read out? Also is 212 out for everyone to download right now and is it ROAR approved yet? Thanks in advance we have a race coming up here in two weeks and I want to make sure we can get all the information out to the racers and so that we are educated as to what to look for in Tech.
Kevin K is offline
Old 10-18-2010, 02:01 PM
  #17522
Team Tekin
Randy_Pike's Avatar
212 has led's 3 and 5 flashing to distinquish it from 208, YES 212 is ROAR Approved.
Randy_Pike is offline
Old 10-18-2010, 02:20 PM
  #17523
RDOUBLEDAY's Avatar
Where can we get 212???????
RDOUBLEDAY is offline
Old 10-18-2010, 02:25 PM
  #17524
Senna Racing's Avatar
212 what's this
Is it just for spec classes or is there any other changes from 208
Senna Racing is offline
Old 10-18-2010, 02:48 PM
  #17525
20 SMOKE's Avatar
Trader Rating: 103 (100%+)
212 has new features:
Minimum Throttle: This setting will take ANY deadband out of the throttle feel. Going up increases the punch feel.
Minimum Brake: Takes away any gap from nuetral to brake transition.
Better more improved brakes....
Originally Posted by Senna Racing
212 what's this
randy post
20 SMOKE is offline
Old 10-18-2010, 03:02 PM
  #17526
jammincrtjames's Avatar
what range of gearing would you run in SPEC MODE using a 17.5?
jammincrtjames is offline
Old 10-18-2010, 03:25 PM
  #17527
20 SMOKE's Avatar
tc,12th,wgt?
20 SMOKE is offline
Old 10-18-2010, 03:31 PM
  #17528
STLNLST's Avatar
Guys out here are running anywhere from 3.8- 4.1 depending on track and layout.
STLNLST is offline
Old 10-18-2010, 04:57 PM
  #17529
Team EAM
Trader Rating: 79 (100%+)
I think that 212 will be posted on the Tekin site in the next day or so (20th maybe?). There are a few other adjustments that Randy mentioned that really can change the throttle and brake "feel".
I ran a 4.15 on carpet 17.5 in the spec mode. Full timing on a duo 1 or 2. It was only coming off the track at 130 with a fan.
EA
EAMotorsports is offline
Old 10-18-2010, 05:09 PM
  #17530
EA
Was this at Dirlas? You gonna race this weekend?
Old 10-18-2010, 07:47 PM
  #17531
nashrcracer's Avatar
yes and this weekend is the halloween classic so next weekend wil be running at thunder. ea was fast on the new layout.
nashrcracer is offline
Old 10-18-2010, 08:40 PM
  #17532
pakk's Avatar
Trader Rating: 80 (100%+)
Why do we need two different sets of blinking lights for the non timing mode?
pakk is offline
Old 10-18-2010, 08:42 PM
  #17533
Suspended
Incase the main one goes out there's a backup for the people teching to see to save you from being DQed
PFKAOG is offline
Old 10-18-2010, 08:44 PM
  #17534
RCknight's Avatar
What software version do I need for VTA? 200? Thanks
RCknight is offline
Old 10-18-2010, 08:48 PM
  #17535
pakk's Avatar
If I were tech'n, I'd wonder why you only had 1 blinking instead of two.......
But let me rephrase my question.
Is there something different about the 212 stock spec that would require it to have different blinking LEDs?
pakk is offline
