Tekin RS ESC sensored >
Old 08-19-2010, 09:44 AM
  #16636
Akudou's Avatar
Thats what i was thinking of doin too. So i just mantain the boost timing at 35? cos the setting im using at the moment which cause alot of damage has an fdr of 10.2 was fast to reach the end of the straight of 80 feet but the power seems able to push more than 80 feet. Felt like the straight wasnt long enough for the power. Thanks will give your setting below a try but any advise on fdrs as well or i just stick to the one i am using?
Originally Posted by M-Technic
Turn the turbo down to 6-8. Turn the turbo ramp down to 1. Change the RPM range to something like 10,000 start, 30,000 end. That should tone it down a lot.
Akudou is offline
Old 08-19-2010, 02:01 PM
  #16637
M-Technic's Avatar
Trader Rating: 15 (100%+)
I would probably turn the boost down too. What were your temps like? The one thing I am not sure on is the gearing.
If your straight is that short I would possibly even turn the turbo off and only focus on the boost. Start by turning the turbo off, boost at 20, and keep the rest of the settings the same. Work with that and add a little bit of boost until you are happy. Experiment with the gearing some. You might want to gear down to a 10.5-10.75.
M-Technic is offline
Old 08-19-2010, 02:43 PM
  #16638
Originally Posted by rayrush
Hi, i am about to get tekin rs 21.5 combo. What gauge wire do i need and do i need any other connectors or bullets? Thanks, this is all new to me
The combo comes with wire for connecting to the motor. It's got enough for the battery, too, but doesn't have a battery connector. You'll have to get that separately... whatever type is appropriate for your battery.
-Mike
grippgoat is offline
Old 08-19-2010, 03:03 PM
  #16639
I will try again
Hi all
Well, i have some issues with my Tekin/Novak Balistic 10.5 combo.
I have tried everything, FDR from 5.7 - 6.7 all combinations of timin etc etc
Should i go for RPM(high FDR or torque ( low FDR)
whatever i do, i CANT get it hotter than 50 degres C
Track 1 has a 36 meter straight, lots of turns.
Track 2 har a 45 meter straight, fast and flowing.
One thing that i can figure out, is, motor timing. On my Novak it is a N mark, this is 15* som when setup says 5, that is two mark to minus side???
Another thing, if end RPM is set to 14K instead of 20K will topspeed be the same?
Any suggestions for this two tracks?
And, is the Balistic wrong motor? should i go for an X12 instead. Seems like my buddies hwo run X12 has more RPM..
Lots of questions, but i em desperat to get a fast setup, other have Tekin and gets around a lot faster, even though we where equals before Tekin
Finken is offline
Old 08-19-2010, 03:17 PM
  #16640
hairy's Avatar
Originally Posted by Finken
I will try again
Hi all
Are you saying that you are not competetive with this set up or are just wanting to get the motor temp up?
hairy is offline
Old 08-19-2010, 03:20 PM
  #16641
I will try again
n
My main concern is, the RPM range, and if Novak is a less RPM willling motor...
Finken is offline
Old 08-19-2010, 03:58 PM
  #16642
I will try again
Hi all
The 'N' mark is 30 degrees i know as i asked Steve weiss about it when i was having trouble with my Tekin and Novak combo. You can download the timing info here http://www.teamnovak.com/tech_info/i...tes/index.html
BILKO1 is offline
Old 08-19-2010, 04:12 PM
  #16643
Jochim_18's Avatar
I'm also running Tekin/Novak combo and they run cooler and fast which really good it makes the Motor more efficient.
Jochim_18 is offline
Old 08-19-2010, 04:18 PM
  #16644
Akudou's Avatar
Temps was just nice at 61 deg c. Will keep what you advise in mind. Thanks and will update you after another run later.
Akudou is offline
Old 08-20-2010, 03:10 AM
  #16645
He isn't competitive enough. I had over a second lower laptimes and 2 laps more in 5 minutes than he had at our last race.
Hurrle is offline
Old 08-20-2010, 04:18 AM
  #16646
after having weird brake delay issues with 208 i went back to 203 and everything is nice again, i'll just stick with it.
gameover is offline
Old 08-20-2010, 05:05 AM
  #16647
Trader Rating: 27 (100%+)
Guys i really want to go back to 203
Between my brake issues and no power i just want to try it.
Can anyone tell me exactly what i gotta do? I really want to have this ready for sat. Thanks
mist467 is offline
Old 08-20-2010, 05:34 AM
  #16648
Hehe Hurrle, you are here too
Well, LRP`s and one Tekin is on their way, testet a lot of thigs last night, and my Novak simply doesent rev to the RPMs i want. I get battery fade before heat takes the motor.
If its a failiure to the motor or what i dont know, i just now i will throw the Novaks as long as i can into the woods haha
Finken is offline
Old 08-20-2010, 05:35 AM
  #16649
I did it last week , just delete the hotwire progr from your computer then install the v203
When you plug the speedo in it tells you your running a differant version and it updates tge speedo back to v203
sidecarphil1 is offline
Old 08-20-2010, 05:46 AM
  #16650
do you have a copy of 203 you can email me?? Email is in my sig. Thanks
mist467 is offline
