Airtronics Mx-3 Fhss >
Old 06-03-2007, 07:06 PM
Default Airtronics Mx-3 Fhss
Hey guys so i read that they were slated for a early june release, does anyone have any news on this? And how does this compare to the 3pm FASST? I read that Fhss is theoratically better than DSS.. Whats the verdict?
dorick is offline
Old 04-07-2008, 05:42 PM
LOW ET's Avatar
Trader Rating: 109 (100%+)
for those using this radio, do you have to bind the receiver to the radio every time you use it?
LOW ET is offline
Old 04-07-2008, 05:47 PM
Suspended
June release? I just bought mine a week ago from amain hobbies.
Works great for me. I only needed to bind once.
403forbidden is offline
Old 04-08-2008, 03:20 AM
Pauly6401's Avatar
Trader Rating: 53 (100%+)
It's been out since at least the beginning of the year or so - runs about $180 with the transmitter and receiver from all the big name hobby shops.
Pauly6401 is offline
Old 04-08-2008, 06:30 AM
Take note of dates of posts guys. The original post was last year.
JoelV is offline
Old 04-08-2008, 12:20 PM
LOW ET's Avatar
i know the date of the original post, but isn't this the mx-3 fhss thread? that's the reason i put my question here. why start another thread? i ask my question because i have about ten receivers working off this radio and almost everytime i want to use it i need to re bind the receivers to the radio.
LOW ET is offline
Old 04-08-2008, 01:26 PM
Pauly6401's Avatar
Do you set each receiver to be a different model? I would think you wouldn't have to rebind if you did that, but then I've only had the radio for about 3 days now.
Old 04-08-2008, 01:35 PM
LOW ET's Avatar
yes, different model # for each receiver.
LOW ET is offline
Old 04-14-2008, 05:01 AM
zenithrr's Avatar
I think there are only 2 type transmission we are talking about here, FASST vs DSS. FHSS is a general group name for 2.4Ghz.
Frequency-hopping spread spectrum - FHSS (group name for general spread spectrum 2.4Ghz devices)
FutabaŽ Advanced Spread Spectrum Technology - FASST (Futaba's 2.4Ghz)
Dynamic Spread Spectrum - DSS (Sanwa/Airtronics's 2.4Ghz)
as I read about sometime ago. the FASST has a bit faster respond time because the frequency-hopping action is sequential (less processing time if same type of processor is used). DSS uses dynamic frequency-hopping which means transmiter send out a code first before receiver can use it to synchronize (more processing time if same type of processor is used).
the DSS is cabpable to have more clients tough, about 2 billions.
zenithrr is offline
