Old 04-09-2008, 04:08 PM   #1
Default problems with XRAY T2 07'
why my car goes once left once right when i open the throtle?i use a lipo battery 270grams.should i add weight??
DKOKKKK is offline   Reply With Quote
Old 04-09-2008, 04:13 PM   #2
todd8603's Avatar
Default Lots of possibiliites
1) Tweak - remember that tweak assumes the car is balanced ot begin with
2) Differential condition or quality of build
3) Shock oils must be same on both sides of the car if different this throttle push is likely also
4)droop settings in the front must be equal side to side.
My bet is the car is not balanced and therefore tweaked causing the car to squirt away from straight line.
todd8603 is offline   Reply With Quote
Old 04-09-2008, 07:34 PM   #3
t4m1y4niac's Avatar
don't forget bearings...
t4m1y4niac is offline   Reply With Quote
Old 04-09-2008, 09:51 PM   #4
Geezatec's Avatar
Electronic glitch of your TX & RX. Check Battery Voltage, location of antenna, Motor caps, Motor brushes if not useing brushless motor.
Geezatec is offline   Reply With Quote
Old 04-10-2008, 04:38 AM   #5
tc3team's Avatar
Also, if you have previously been racing with nimh cells, there is a good chance you will need to change the preload on your suspension, or add weight to the lipo side of the car to get a good weight balance
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 04-10-2008, 04:46 AM   #6
turd ferguson's Avatar
Send a message via AIM to turd ferguson
Another thing to check is your one-way bearing (if applicable) and your blades on your driveshafts. I've had the car pull one direction on power because of those conditions
TrakPower, Speed Passion USA, Pro-line, Stickit1 Racing, LiveRC.com
turd ferguson is offline   Reply With Quote
Old 04-10-2008, 11:11 AM   #7
ottoman's Avatar
R/C Tech Charter Subscriber
Hey Turd...
Also change your servo horn... sometimes they strip out and you cant tell by moving them by hand... had this happen to me a time or two
ottoman is offline   Reply With Quote
xray t2 problems?? fishnfst Electric On-Road 6 10-09-2007 09:18 PM
Anyone have problems with non-countersunk topdeck on XRAY T2 Got Xray? Electric On-Road 54 05-18-2006 06:54 AM
XRay diff squeaking, other problems to D_o_S Electric On-Road 9 04-22-2006 10:06 PM
Xray website problems ChrisP Electric On-Road 8 12-22-2004 02:58 PM
Some problems zachzachz Electric On-Road 28 09-06-2003 11:37 PM
SEO by vBSEO 3.5.0
