Old 10-02-2003, 01:36 PM   #106
Trader Rating: 24 (100%+)
Take a look at this link. It should give you some great ideas. Good Luck
Evoracer is offline   Reply With Quote
Old 10-02-2003, 01:45 PM   #107
Nozauta619, The FF02 is legal in GT1, GT2 and GT3. Personally ,I have very little experience with this chassis. I suggest you contact Tamiya or get in touch with the folks at Burien Racing up in Washington State. www.burienracing.com. They have a great Tamiya racing program and they only deal in Tamiya parts.
Old 10-13-2003, 06:20 AM   #108
Wannabe's Avatar
Lightbulb
hi guys,
can anyone post picturesin this forum?
Thanks!
Ken
Wannabe is offline   Reply With Quote
Old 10-13-2003, 04:28 PM   #109
Send a message via AIM to Bubblestc3 Send a message via Yahoo to Bubblestc3
wow, i have a fun project on the way...
i bought a TL-01 for $5(yes, $5) and some one bet me that if i raced that car in sportsman stock sedan at socal i would come in last place
the car is stock(except the ae screws throughout the car, and the striped spur gear) and my goal is to get a podium with the car in sportsman stock at socal(that is fairley easy with my TC3, but now we are speaking of a TL-01). I will do some testing with the car next weekend and possibally race it the following weekend(hopefully by then the car will be up to par)
what motors are you guys using in stock(i would use one of my monsters, but i heard that the rpm is too much for the m-03(and they have the same gears), hence they are getting too hot and melting the gears, but you guys use what for a stock motor?p2k2?
any help is apricated
thanks
Bubblestc3 is offline   Reply With Quote
Old 10-13-2003, 07:31 PM   #110
weissjim's Avatar
R/C Tech Charter Subscriber
You can run nearly any stock motor in them, just make sure the pinion meshes correctly. Gear it at 21 tooth to start (Monster right?) without the speed tuned gears (too tall [low numerically]). You're gonna need shocks and the Long arm suspension kit to come close. The TL01 won't roll through the corners like your TC3 even with light weight shafts. Keep everything mounted as low as possible, the CG is really high in a TL01, and the roll center is pretty low. They have a very evil tendency to swap ends under braking (I think someone else mentioned this) and like a little softer tire than the TC3.
You can get pretty close to a TC3, but you really gotta want to.
weissjim is offline   Reply With Quote
Old 11-21-2003, 06:27 PM   #111
GReddy's Avatar
Send a message via AIM to GReddy
Default speed tuned gears
for running m tl-01 on straights on the street is the speed tuned gears good for it? will it go faster because i read the forum and someone said speed tuned gears make it slower
here is my car if it dont work then see attachment
[IMG]file:///C:/Documents%20and%20Settings/Sheldon1/Desktop/Rc/Pics/Dsc00052.jpg[/IMG]
GReddy is offline   Reply With Quote
Old 11-21-2003, 06:30 PM   #112
Wannabe's Avatar
Arrow
Oh~!
so that's a TL-01...looks to me as it is a MO3.
Old 07-09-2004, 09:01 AM   #113
Location: austrailia QLD gold coast the place where there is no hobby shops
Exclamation hay looking to upgraid my motor in tlo1 what the best 4 racing?
hay i got a tlo1 a fare while ago and i have only 1 hop up. I have some speed tuned gears and i had a bit of a chat with the guy at local hobby store and he says that u can only have a limmited minium of turns due to the plastic gears and melting at a high tempreture. I think i want to stick with the 19t pinion but have heard somewhere that u can buy aliminum moter mounts and helps if u want diffrent tothed pinions other then the 19t,21 and the 23t what would be the best?. thanks
novak junky is offline   Reply With Quote
Old 12-18-2008, 11:29 PM   #114
Trader Rating: 29 (100%+)
Default TL01 RALLY CAR
aramacir is offline   Reply With Quote
Old 01-21-2010, 04:40 PM   #115
stitchy's Avatar
Anyone know what a TL-01 needs to convert to rally?
Speedtechhobbies.com
stitchy is offline   Reply With Quote
Old 01-21-2010, 09:34 PM   #116
PaPeRo's Avatar
Tamiya made quite a few TL-01 rally kits which were basically the same as the onroad kits so you don't really need to "convert" to Tarmac rally. For offroad you'd obviously want to change the tires to rally blocks or something similar.
PaPeRo is offline   Reply With Quote
Old 01-22-2010, 09:41 AM   #117
stitchy's Avatar
I noticed there were some models that were "TL-01RA." Did those have different arms. shocks and other parts? I'm guessing it did to probably give more suspension travel. Does anyone know what the differences between the "RA" and regular versions are?
Old 01-22-2010, 09:04 PM   #118
PaPeRo's Avatar
There is one RA model and 2 LA models. Anyway the RA version uses suspension components from the LA cars.
Long arms
C hubs
Rear uprights
Front knuckles
Standard length TC shocks
Old 01-23-2010, 08:23 AM   #119
DIrt is main enemy for "wet" gear mesh of TL-01. Once dirt or sand particles enter gearbox, (depend on particle size) it would initiate "chain reaction" damage all gear within, it would emit teerrible noise signal brader .. Then sealing rear gearbox properly is a must for rally, bottom and top side can simply sealed with attaching one or two layers of good quality paper tape or kind of that, and for inner side (behind ESC hole) which the surface is contoured, silicone glue may works as simple semi-permanent sealer.
LOS XXX-S G+
TAM TA-05, TL-01, FF-02, TL-01M, M-04M
ASSO TC3FT, RC12L3, RC10L3
Faiz is offline   Reply With Quote
Old 02-20-2010, 04:17 AM   #120
SO who still has there TL-01??
wantboost is offline   Reply With Quote
Tamiya F103GT Forum SeaKayCarthik Electric On-Road 1 01-08-2007 11:22 PM
Tamiya TRF414M2 Forum reflekt Electric On-Road 77 12-14-2002 08:39 AM
SEO by vBSEO 3.5.0
