Old 03-24-2002, 07:02 PM   #91
dongskie2's Avatar
Default Long Train Running
TL-01's are fun!
Geetoo: Please! kaw kalat dito....
dongskie2 is offline   Reply With Quote
Old 03-25-2002, 12:53 PM   #92
Can anyone post a real TCS legal (2002) set up for the TL01? Some info please.
Technoskid- you take my pic?
wilsonproperties1.com
Isaac is offline   Reply With Quote
Old 03-25-2002, 09:35 PM   #93
Iso Octane's Avatar
Thumbs up
Wow, that is one amazing machine!
I never knew the TL-01 had so much potential.
But I'm curious about this question as well: can a well tuned/modded/hacked TL-01 compete with the likes of TC3s, XXX's, Pro3's, or TAO4s?
Iso Octane is offline   Reply With Quote
Old 03-26-2002, 07:12 AM   #94
work's Avatar
I love my TL01
dongskie: Wild nung email mo!
mailboxck: Wow! nice TL01, loose packs inside
work is offline   Reply With Quote
Old 03-27-2002, 05:15 PM   #95
Trader Rating: 44 (100%+)
Default TL01 Gearing Questions?????
I have a TL01 with 2.2 Sand Paws in the rear and 2.2 Dirt Hawgs in the front and I run a 19 tooth pinion but the motor overheats I was wondering should I get the speedtuned gear set to lower the overall ratio of the car for the bigger tires.
NitroLuver is offline   Reply With Quote
Old 08-13-2003, 11:20 PM   #96
TF
Thumbs up TAO3 ball diff vs. Manta Ray Ball Diff for TLO1
Hello Folks:
What would be the difference in performance between these differentials?
Thanks!!!
TF is offline   Reply With Quote
Old 08-13-2003, 11:57 PM   #97
WC
WC's Avatar
Trader Rating: 28 (100%+)
Default Re: TL01 Gearing Questions?????
Speedtuned gear set *RAISES* your gearing, so it will make it even worse.
WC is offline   Reply With Quote
Old 08-13-2003, 11:58 PM   #98
WC
WC's Avatar
Originally posted by TF
Re: TAO3 ball diff vs. Manta Ray Ball Diff for TLO1
There is no difference in performance, they will both work the same.
Old 09-01-2003, 08:12 PM   #99
TF
TLO1 update
Hello All:
I managed to run the TL01 yesterday. The stuff has the following now:
TA03 Oil filled shocks
Red Spring front
Yellow springs rear
Camber / toe in toe out adjustment
Rear universals
Manta ray ball diff on the rear
Front universals
Hot laps slick tires
Carbon shaft
Carbon gear shafts
Speed tuned gears
Balls bearings throughout
LRP ESC, with capacitors
Paradox stock motor
Front sway bars, stiff
Rear sway bars medium
Paradox 27 turn 24 deg. stock motor with diodes
19 pinion
This seems to be all that I can put in the car.
There are two points that I noticed on the car though:
1. The rear sway bar seems to be hitting the housing for the rear propeller shaft.
2. The car spins out 180 deg. on after it the tops the acceleration.
This happens after I release the throttle from full throttle position to neutral.
Two queries:
1. Is there anyway I can stop the rear sway bars from hitting the propeller shaft cover?
2. Why is it that I am spinning on release of the throttle?
My set-up is pretty low aready... just 5-7 mm clearance from the ground.
To test the set up, I ran it on asphalt tracks, but I normally run the car in carpet tracks.
Also, anything more I can add to the car aside from a better driver?
I want to keep on running stock so an upgrade on the motor is not a priority at the moment.
BTW, the F150 body sucks...it does not have the same handling as other touring car bodies....I thought I would let you know.
Hope to hear from all of you soon.
Cheers,
TF
Old 09-02-2003, 11:15 AM   #100
popsracer's Avatar
Default Tamiya TL-01 Forum
TF;
Make sure you don't have "Drag" Brake dialed into your ESC or Transmitter. This will cause the Car to spin on release of the trigger.
Make sure there is plenty of "Droop" in the Rear. At 5mm ride height, you should have a minimum of 5-6mm rear droop.
I also recommend removing the Sway Bars. Unless your running on a super high grip Track and using Foam Tires, they probably are hurting you. (someone else might dissagree)
Ours has been dialed and is giving the TC3's some competition at our local tracks in the Sportsman Stock classes.
Good luck and have fun.
popsracer is offline   Reply With Quote
Old 09-02-2003, 08:47 PM   #101
TF
Cool TL01 project
Hey Pops:
Thanks for the reply....
Maybe a dumb question, but what do you mean by
"Ours has been dialed and is giving the TC3's some competition at our local tracks in the Sportsman Stock classes."
Also, can you share your set up? I run on both carpet and asphalt tracks.
Many thanks,
TF
Old 09-02-2003, 09:52 PM   #102
GTO2's Avatar
R/C Tech Charter Subscriber
Default Re: TAO3 ball diff vs. Manta Ray Ball Diff for TLO1
Hello Folks:
Thanks!!!
I thought they are much alike although labelled differently. The TA03 should be of a later production. There's the Aluminium plate option to make the diff lighter.
GTO2 is offline   Reply With Quote
Old 09-03-2003, 07:28 PM   #103
WC
WC's Avatar
Default Re: TLO1 update
....2. The car spins out 180 deg. on after it the tops the acceleration.
Basic premise is, you need more grip in the rear.
1) try with equal springs all 4 corners, or softer at back
2) use softer oil at the rears, usually 60/40wt for F/R is good start
3) loosen your rear balldiff or put it into the front
4) lose the sway bars, until you really need them
5) try the toe-in rear blocks...
Old 09-21-2003, 12:28 PM   #104
nozauta619's Avatar
Default optional parts for ff02
i'm looking to purchase a ff02, i would want to know what hop-ups are currently available or is recommended. what parts are cross-over from other tamiya kits (tl01, m03). are there any classes the ff02 can run in tamiya races? would appreciate any help. thanks.
anthony
Kyosho Blizzard EP / Tamiya DF-03RA / Tamiya TA-03F / Traxxas Monster Jams Maximum Destruction / HPI Pro 3
nozauta619 is offline   Reply With Quote
Old 10-02-2003, 07:04 AM   #105
BRANDED's Avatar
Default nd help
hi guys,
i juz got a tl01 with bearing frm my fren......like to knoe wad hop up i shd get for my car........gear, motor, etc....thx alot!
BRANDED is offline   Reply With Quote
Tamiya F103GT Forum SeaKayCarthik Electric On-Road 1 01-08-2007 10:22 PM
Tamiya TRF414M2 Forum reflekt Electric On-Road 77 12-14-2002 07:39 AM
