Tamiya TL-01 Forum >
Tamiya TL-01 Forum
Like Tree7Likes
Tamiya TL-01 Forum
Old 08-19-2011, 11:54 AM
  #166
Trader Rating: 30 (100%+)
Originally Posted by joy722
I'm used The TL-01 for Drifting...anyone know..how to make TL-01 one way and CS (Counter Steer).tq
You will need to search either for the actual TL-01 one-way or as someone else mentioned to look for a TA03 one-way (suppposedly, these are out of production, but they are out there if you search good). That's pretty much the only ways you will find out. Good luck!
In regards to countersteering a TL01, I think you're out of luck. Never heard of anyone countersteering a TL01 especially if there isn't any gears from another car that would fit and also alter the drivetrain ratios between front and back. You'll probably need to buy another chassis to countersteer.
wrxnfx is offline
Old 08-19-2011, 11:58 AM
  #167
Originally Posted by 1101
Hi there.
Will TT01 cv's fit a LA ??
A bit of TL color
Depending on which TT01 cv's you are looking at buying. If I recall correctly, the 42mm universals from the TA04 fit the TT01 and these will also fit the TL01 both regular and LA. Had the same set of TA04 universals on both my TT01 and TL01 when I had them.
wrxnfx is offline
Old 08-19-2011, 05:16 PM
  #168
Turns out the TT01 cv's fit but are slightly too lond & bind : found out the hard way
TA04 are the one that are an exact fit
1101 is offline
Old 08-19-2011, 05:23 PM
  #169
Originally Posted by WILDMAN442
So other than RCmart,
Any other places to locate parts for these beasts?
Ebay is the best place. It long out of production so some parts will be hard to find
If its the original version (Not the LA) , then some M03 parts are the same: diff, steering knuckle,rear hubs, C upright(forgot its proper name) , diff outdrives.
Check the underneath of the chassis & where the suspension arms etc bolt on for cracks. But a new replacement chassis is really cheap & still available.
Some TA04 parts are the same as well,suspension arms?(LA), dogbones,CV's, depending out what TL version
1101 is offline
Old 08-19-2011, 05:26 PM
  #170
Awesome
I plan on mostly just cruising thing around in front of my house as there is really no where around here locally for on road stuff
Thanks!
Justin
WILDMAN442 is offline
Old 10-29-2011, 01:36 AM
  #171
Some pics of my TL-01 chop job - rebuild no.5
cut out a section of the chassis & glue it up. You need to cut down the driveshaft as well.
Re-enforce the top & bottom. I went for strong rather than pretty. A bit messy (Im impatient)
A better option is to plastic weld it with old parts trees & soldering iron , or put plastic through a hot glue gun. I'll try that next time, maybee.
Add baja (TL01b) arms. Helps it stop rolling. 9T Ezrun motor + speed gear set. Foams really help grip.
The red Yeah racing shocks are rubbish. get the cheaper YeahRacing Silver ones instead.
Batt holders are from M05. Helps to protect the ends of the lipo. They work MUCH better than standard TL batt holder ends.
Add mini body. Got out & thrash the thing. Time to replace that body perhaps??
This car will wheelstand with the 9T motor.
1101 is offline
Old 10-29-2011, 07:00 PM
  #172
Default TL 01
Hello everyone,
I just want to say that I still have my tl01 after buying it new when it came out. Dont have the Mustang body but I have spare bodies. I took out the original electronics & had some newer ones laying around.
After reading & seeing what could be cut out, I have a project ahead of me. I cant believe how much can be cut out of it to reduce wieght.
Im thinking about getting the EZRun 13.5 brushless system for it but I am concerned if the plastic gears can handle that motor. I seen some people said that I would have to upgrade the gearing. I also seen people say that I have to get bearings for it.
I will check RCmart for some of the parts I will need. I cant wait to get started on this project. Not sure how long it will take me but I have lots of time.
Just wanted everyone to know that I still have this & I like driving it.
crasher19 is offline
Old 10-30-2011, 12:44 AM
  #173
The plastic gears will easily cope with 13.5T. Ive been running 9T for 2+ years & a friend runs 5T
Definitely get a bearing set.
1101 is offline
Old 10-30-2011, 05:14 AM
  #174
Does RCMart have the bearing set or can I get them at a local hobbyshop? Also do you know the size of the shocks? I want to put some threaded shocks on it as well. Not sure what size they are.
Old 10-30-2011, 08:54 AM
  #175
Get the toe inn rear hubs while your at it.
Dunno if those fits the LA arms if you are going for those.
MatsNorway is offline
Old 11-10-2011, 06:30 AM
  #176
Where do i buy bearings to my TL-01?
i was looking at RCmart and only found yeah racing.. and im not buying those.
Old 03-18-2012, 05:31 PM
  #177
The TL01 is back...
Orion 7.4v Lipo, SpeedPassion 13.5T brushless motor, Bluebird servo, Airtronics MT-4 controller.
Reinforced the carbon shaft with additional bearings.
New front suspension arms, c-hubs and Ta04 steering knuckles.
More info about Project TL01 here.
rccartips is offline
Old 11-01-2012, 04:32 AM
  #178
Cool. Got more pictures of the servo?
Old 11-12-2012, 08:53 AM
  #179
Do you have the part number for the parts from TA04?
Old 11-12-2012, 09:00 AM
  #180
SteveM's Avatar
Trader Rating: 165 (100%+)
Try Boca bearings at http://www.bocabearings.com/
SteveM is offline
