New TEAM WAVE racing brushless system
#976
Anyone have some idea of how far away the RB-12 is for release??? it's the only pice i am missing for the my 12'th scale
#978
#979
BL Motors differences
Hy!
Can anyone give an overview wich motors have wich characteristics (Timing, Heatresistance, ...)?
And wich one are recomended for use with these timeshift/Turbo settings?
Orion - LRP X11/X12 - SpeedPassion - TeamWave - Tekin - Novak - Fantom
Maybe someone have a more knoledge to share...
Greetz Rainer
Greetz Rainer
#981
Hy!
Greetz Rainer
Greetz Rainer
#982
lrp x11 and x12 are very torquey motors but it seems the x12 have more advance standard from what i have heard. Speed passion is quite similar but has a lot of bottom end power. team wave is almost the same as speed passion. Don't know about tekin. Novak does not have much bottom end but a lot of middle acceleration and good top end. Fantom is trinity which duo1 is the best of all good balance of speed torque power and mid acceleration. duo2 same thing but runs a little hotter so gearing needs to be more spot on and nemesis just fades when heated although with revy rotor not to bad but duo's are my preference as they perform well to start with and can add timing easily!!
Greetz Rainer
#983
RB12
i have been testing the unit for a couple of months and the unit is very smooth and has not had any problems.
i know that max was trying to build a booster within the unit this will be much better.
The next test for me with the rb12 is at the 2010 Euro's at the begining of March.
Cheers
Alan
#984
I'm running 11.5 motor. Want to know how should I setup the Turbo in RB-50 and RB-S. I have both ESC but I can't really see any faster then other people running ESC with no turbo? What should be the turbo setting? What should be the gear ratio?
When I holding my car with full throttle, I can see the green light goes on (turbo kicks in) and hear the sound form motor with sudden more rpm. But on the track, I can't see or feel any different.
I'm using new 50C SMC and IP batteries. I know you may say my battery is weak.
#986
#987
I have some questions.
This is for our stock class.
Can the Teamwave run sensorless or when that is not posible start in sensord mode and go over in sensorless?
#988
RB50 and TP 11.5R
Waiting package of RB50 from my HK colleague, any info track test of RB50 with Team Powers 11.5R? please kindly advise,, Thanks,,
#990
I ask this because I'm making the rules for 2010 for our stock class (17,5T).
Most of them a beginners. The class is our beginners class but some drivers stay in that class because they don't have time to train a lot.
Now i'm making the rules that all the speedo's must be sensor-less and from LRP are the LRP SXX ss and the SPX for-bidden. But 1 of our drivers bought the RB50.
Now I want to now if this speedo can be set to a speed that is the same as a LRP TC. This way he can drive with his speedo.
I don't want that he must buy a new speedo for the few races he drives by the club. He races for fun and I want that he can have fun in the races with his speedo.
So all the information about the possibilities for this speedo to set it on LRP TC speed are welcome.
He has also the card to adjust the settings.
